Rotor Screws Missing
Hey guys, I am going to replace my rotors since they're going bad especially the passenger side rotor is loose right now, but the weird thing is that I can't find the rotor screws that the TL DIY calls to remove. I had my tires changed and so I looked at the rotors for the screws, but couldn't find them
the holes aren't even there for the screws
any ideas?
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
any ideas?
Whats up with RDX owners?
No big deal. The wheel and caliper holds the rotor on anyway.
You may have some aftermarket rotors from the person who owned the car before you. Either way its no big deal. In fact you're lucky cause sometimes they are hard as hell to get off and ussually need a impact driver to get them off if they are oem.
Don't sweat it.
Don't sweat it.
the two counter sunk screw holes are just for screws to hold the rotors in place during car assembly. The threaded screw holes are there to help you get a rotor free from the hub. Insert bolt of correct thread and tighten it until the rotor pops off the hub. Or do what I do and hit it with a BFH.
I Wanna Beer
Werd. Drilled out the last set and didn't put them back. As others have said, they're only there for assembly at the plant and aren't needed. This is the first vehicle I've owned that's even had them.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
