RL Calipers Fit behind 05 TL 17" rims!
Old 11-18-2010, 04:50 PM
  #321
AM To WDP In My Garage
acura_dipset_tl's Avatar
Originally Posted by aznboi2424
Just a couple of things while I was looking for info and talking to Paul:
-You can use the stock hoses directly to the RL calipers, forget the metal rigid lines.
-350Z Brembo sized rotors seem the best size to use. They are bigger and the bolt holes are tighter around the hub then the non-brembo size (vibration concern). While the brembo sized rotors are thicker, Paul says they will still fit.
- I measured pads and calipers and you need at least 60mm of space from the rotor to the spokes of your rims. This was a critical number for me in determining if my wheels would fit and what size of spacers I would need.
I know what you mean about the rims fitting over the bracket, I had to cut a small piece of the bracket in order for my rims to clear.
Old 11-18-2010, 05:52 PM
  #322
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,450 Likes on 4,972 Posts
Yea, 19s will clear everything with no problem, but 18s and especially 17s you will need to grind down the studs on the bracket.
Old 11-18-2010, 06:08 PM
  #323
aznboi2424's Avatar
you do? fudge. I didnt get that part. I dont have a cutting tool or a grinder. I was just talking about getting the caliper to fit behind the wheels.
Old 11-18-2010, 07:10 PM
  #324
civicdrivr's Avatar
Yep. I scratched up my freshly painted Works when I tried mounting them the first time
Old 11-18-2010, 07:26 PM
  #325
I used a hack saw from wal mart, only $8-$9 bucks. First put the bracket, and the caliper on, then bolt everything up including the rotor. After that just cut what's necessary with the hack saw, make sure you cover the caliper for protection, you don't want to slip and accidentally nick your caliper.
Old 11-19-2010, 06:56 PM
  #326
anthracitecl's Avatar
^ yep! man i was worried. cause i didn't think hak saw could cut that studs. I was suprised that hak saw worked pretty well!!!
Old 11-19-2010, 07:19 PM
  #327
aznboi2424's Avatar
You had the same problem?
I asked Paul and he said he wasn't even aware of it, he said there would be only an issue on 17s
Old 11-19-2010, 08:29 PM
  #328
no. I helped acura_dipset_tl. It was fun though.
Old 11-19-2010, 09:05 PM
  #329
99cfenvyv6's Avatar
subscribing to this thread for later reference.
BTW, what area of the bracket did you have to cut & how much?
Old 11-19-2010, 10:39 PM
  #330
p.diddy's Avatar
yep paul had to cut the studs down on my brackets to get my wheels to fit too. the brackets are perfect just the studs on them are just a tad but long. but just cut them down a smige and your fine.
Old 11-19-2010, 11:55 PM
  #331
aznboi2424's Avatar
Just the studs, I think they are the black bolts in the picture in the first post.
I'll let Paul know that they need to be cut. How much to fit 18" rims?
Old 11-20-2010, 12:02 AM
  #332
civicdrivr's Avatar
Just put everything together and cut the stud leaving a thread or two above the nut.
Old 11-20-2010, 12:56 AM
  #333
Your best best is to do it the way I mention a few post back, because you don't want to risk it and over cut the stud then you'll be S.O.L.
Old 11-20-2010, 03:33 PM
  #334
Mr. L.E.D.
KnightRyderV's Avatar
i also noticed that the bracket doesnt sit flush against the caliper because it seems like its about 1-2mm too wide so that will need to be shaved down a little bit too so that it sits perfectly against the caliper. no big deal for me since i have tools to take care of it but for the average person it may be a slight issue.
the bracket should be touching the flat part of the caliper and you can see the marks i made to indicate what areas need to be shaved down a tiny bit to get it to sit flat.
Old 11-20-2010, 04:45 PM
  #335
no no man. Don't shve it down. when you initally tightening down the caliper you just make sure it crushes into the brack, the bracket is purposely about 1/8"(I think) wider than the tits on the bottom of the caliper, this will make for a very tight and secure fit when crushed in. I asked Paul about this before i installed mine. I hope you didn't shve.
Old 11-20-2010, 05:53 PM
  #336
civicdrivr's Avatar
DO NOT SHAVE THE BRACKET ITSELF!
Its made slightly oversized so when you tighten down the caliper it crushes a bit of the bracket and creates a very snug fit.
Old 11-20-2010, 06:40 PM
  #337
p.diddy's Avatar
lol i said the same thing when i read his post. nowhere have you seen shaving the brackets is a good thing. just the studs.
Old 11-20-2010, 08:05 PM
  #338
X4 DO NOT shave the bracket .
Old 11-22-2010, 12:21 AM
  #339
Mr. L.E.D.
hahaha, message received.
i wont shave it. thanks for the heads up guys.
Old 11-24-2010, 12:15 AM
  #340
aznboi2424's Avatar
got your brackets already eh Vimal? lol
Old 11-28-2010, 08:16 AM
  #341
LFG RANGERS!!!!!!!!!!!
e30cabrio's Avatar
Received 1,982 Likes on 1,359 Posts
Rotors needed for this here:
https://acurazine.com/forums/showthr...4#post12521694
Old 11-30-2010, 03:10 PM
  #342
aznboi2424's Avatar
Those 350Z brembo sized rotors are friggin heavy, 22 pounds each!
Old 11-30-2010, 03:15 PM
  #343
e30cabrio's Avatar
They are the rotors needed for this swap.
Old 11-30-2010, 04:05 PM
  #344
civicdrivr's Avatar
Stock front is about 18lbs each. The RL calipers weigh about 7lbs. The difference is null.
If you are that concerned with weight, get a set of two piece rotors with aluminum hats.
Old 11-30-2010, 04:31 PM
  #345
aznboi2424's Avatar
Nah, I guess I havent touched the stock ones recently so these felt really heavy compared to the last ones I lifted (7th gen accord)
Old 11-30-2010, 04:36 PM
  #346
e30cabrio's Avatar
Try the 26lb 14" G37S rotors if you think these are heavy.
I just cannot rationalize spending 2k on rotors.
Old 11-30-2010, 04:56 PM
  #347
civicdrivr's Avatar
I looked at the 2 piece 350Z rotors for this project at first but the best I found was $400 each. No thankyou.
Old 11-30-2010, 05:12 PM
  #348
e30cabrio's Avatar
400 is cheaper than I found but I was looking for these dinner plates.
lol
Old 11-30-2010, 08:18 PM
  #349
civicdrivr's Avatar
$400 EACH. But yea, you were looking for something with a bit more girth.
Old 11-30-2010, 10:44 PM
  #350
B A N N E D
friesm2000's Avatar
actually try some like 93 Lexus LS400 rotors, those are really heavy f@ckers, i don't know the actual weight of them though
Old 11-30-2010, 11:32 PM
  #351
really? i have a 94 LS 400 but i never had to change the rotors.
i need to sell that car it just sits there. lol
Old 12-01-2010, 12:01 AM
  #352
B A N N E D
friesm2000's Avatar
before you sell it, you should pull a rotor off and weigh it, and see how heavy it truely is
Old 12-01-2010, 12:18 AM
  #353
That's too much work Lol. How bout i sell it to you and you weigh it.
Old 01-14-2011, 01:38 PM
  #354
3.5 psi
gnuts's Avatar
has anyone just bought the used calipers and thrown them on without rebuilding them?
Old 01-14-2011, 04:51 PM
  #355
e30cabrio's Avatar
I did. They were fine. ymmv.
Old 01-14-2011, 05:03 PM
  #356
3.5 psi
gnuts's Avatar
good to know thanks. i still think they look sweet without powdercoating.
Old 01-14-2011, 05:50 PM
  #357
e30cabrio's Avatar
I was very happy with them as they came.
Old 01-14-2011, 05:57 PM
  #358
Bonki' Ehrite!
ANC297's Avatar
Very tempting as I am looking for a bbk.
My only issue is I just got new tires on stock wheels...Which apparently do not clear the calipers? 02tl-s
Old 01-14-2011, 06:04 PM
  #359
civicdrivr's Avatar
Not without spacers, and thats if the barrel clears.
Old 01-14-2011, 06:46 PM
  #360
p.diddy's Avatar
i did and their fine.
Quick Reply: RL Calipers Fit behind 05 TL 17" rims!
