RL Calipers Fit behind 05 TL 17" rims!
#523
@thisaznboi88 I have these the 17x7 rims are those the ones you have
http://www.originalwheels.com/acura-...ms-71725-b.jpg
are those the ones you have?
termo001 (04-19-2012)
#527
If you bought the calipers for $65 each then you got a great deal they usually cost more and in regards to powdercoating both of those prices you've been quoted are good but just like anything the cheapest isn't always the best.
#528
opps i just seen this
I will see you at IA this weekend
That about right. Avg price for paint Caliper is $50-75 each. Also don't for get you will needed buy rebuild kit after powder coating is done. I got OEM ones for $50 each
#529
sweet guys thanks a lot yeah i got the calipers for $150 shipped to me. i know cheapest is not always the best Im trying to do my research first before i make a decision the biggest thing to me is the color Im so gonna copy Civicdrivr lol i love that color! what is it Candy Blue???
Is this a good site for the rebuild kit?
http://brakeperformance.com/brake-ca...d-.php?did=112
#532
I can get a set from ebay for 25 shipped. Go half?
I'm glad you posted this cause I realized I put the washer between the caliper and the bracket. Got me an extra 1/4 inch of sweep now lol
#533
so what is the center bore of the 2nd gen CL,66 or 64? I need to get some hub centric spacers and I just wanna make sure i get the right ones. the bolt pattern is 5 lug 4.5" (114.3mm) correct? I should be getting my RL calipers back this week maybe tomorrow
termo001 (06-19-2012)
#539
can anyone recommend a good quality brake fluid? I read racing fluids, like ATE Blue, absorb water (which of course lowers the boiling point) much faster than OE grade DOT3 fluids and to use Honda DOT 3/4 brake fluid instead or you run the risk of corrosion. What would you do?
#542
LFG RANGERS!!!!!!!!!!!
https://acurazine.com/forums/car-parts-sale-361/ebc-slotted-rotors-799629/
The thread is closed but pm me if interested.
#543
what is everyone with BBK using for a spare tire? a full size 05' TL wheel? Or maybe a stock CL wheel with spacers? I need to buy something, as I feel quite vulnerable driving around knowing my spare tire is useless with my RL calipers.
AustinTaper (07-03-2012)
#545
What are you guys using to rebuild your calipers? OEM or aftermarket? OEM is around $100 for both whereas aftermarket is much cheaper. Would I have an issue going with aftermarket rebuild kits, let's say from Autozone or RockAuto?
Also.. I currently have XXR 522s (19.8.5 +38).. would I need spacers or will these calipers fit fine?
#546
If they don't have a lip and the spokes are pretty concave then they should fit.
Hmm I might pick one up. I was just being cheap and planning to swap a rear wheel to the front and put the spare on the back if one of the front wheels had a flat.
#547
#548
here's a thread that might help some people
https://acurazine.com/forums/showthr...highlight=RPF1
The following 2 users liked this post by gnuts:
aznboi2424 (07-06-2012),
civicdrivr (07-06-2012)
gnuts (07-10-2012)
#560
^Aegean, ronjon wheels click here
