Rim Help
Old Mar 21, 2004 | 05:12 PM
neel1109's Avatar
Rim Help
I have a 01 CL and i been looking through the forums and i see a lot of different numbers...i just wanted to know the maximum wheel size i can get for my CL without it rubbing and what offset i shoud get?
thanks
Old Mar 21, 2004 | 05:50 PM
brian6speed's Avatar
Lone Wolf
Someone else will be able to answer this better than me, but you can go up to a 19x8. 8.5 is too wide, and looks weird on the car. As far as offset id say between 40-50(im not exactly sure). I got a 45 offset on mine. Hope this helps.
Old Mar 21, 2004 | 08:14 PM
niz181's Avatar
Brian is right, I have 19x8 on my 03cl-s and my offset is +49 with 235/35 tires dropped on Comptech and it doesnt rub, but the car is still too high for me in the back almost 3 fingers, so if this sounds good to you, will be alright. hope i was helpful
Old Mar 22, 2004 | 07:43 AM
G-UNIT's Avatar
Poppin them thangs
depends on the drop, and the size of tires. This thread should help you out...ppl list there drop, rims, offset and tires and say if they rub or not...
http://www.acura-tl.com/forums/showt...threadid=73982
btw, im on
18 RH EVO C2's
225/40/18
+42 offset
H&R Sports Drop
NO Rubbin whatsoever...
but each rim is different...
Old Mar 22, 2004 | 08:30 AM
Linner's Avatar
im on an eibach drop with 45 offest 18x7.5 235/40/18 tires and i rub.. I rolled the fender a bit and i dont rub as much but still do over railroad tracks and big bumps. Go with 225 tires and u chouslnt have any problems
Linner's Avatar
oh i forgto try going higer then a 45 offest too
Old Mar 22, 2004 | 08:44 AM
G-UNIT's Avatar
Poppin them thangs
neel1109
it might be easier to post what types of rims u were lookin at...im pretty sure someone here might have them already....
Old Mar 24, 2004 | 10:10 AM
Lone Wolf
I have 17x7.5 with 45 offset with koni/neuspeed shocks(1 perch lower than lowest setting on konis), neuspeed sport springs, and 235/45-17 with no rubbing at all. I do have a camber kit installed both front and rear too.
kev87a
Nov 2, 2015 07:40 AM
Gout
Nov 2, 2015 12:22 AM
kev87a
Oct 18, 2015 02:03 AM
dirleton
20
Oct 16, 2015 01:48 PM
