Replacing Fuel Pump...Should I replace the Filter too?
Old Nov 6, 2015 | 08:20 AM
tr59210's Avatar
Question Replacing Fuel Pump...Should I replace the Filter too?
I think the fuel pump is slowly dying. A few days ago I tried starting the car up after coming home and it just wouldn't start. Sounded like it wanted to, but then it would die immediately. Seemed like a fuel delivery problem or the ecu was preventing the car from starting for some weird reason. I had to wait ~10 minutes before it cranked back up, but it seems to be doing okay lately.
I've replaced the main relay a <1year ago, but it still has this symptom at times. I can't hear the pump wind up anymore either before the car cranks up which I used to be able to hear. This leads me to think of the pump as the culprit.
But the question is should I replace the fuel filter while I'm at it since the pump & filter are both located in the tank?
Not sure myself really since I've heard these are "lifetime" filters.
Thanks!
Old Nov 6, 2015 | 10:49 AM
If you use the Denso 9500161 Pump & Strainer Set ($80.79) from rockauto it gives you the filter with the kit versus the OEM 17040-S3M-A00 PUMP SET, FUEL ($251.18)
More Information for DENSO 9500161
#3 on link below:
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
Old Nov 6, 2015 | 10:56 AM
RedRyder's Avatar
Be a better driver
If you can get to the filter at the same time, may as well change it.
You could try adding solder to the solder points on the main relay, though I would think it wouldn't be having problems just being a year old.
Old Nov 6, 2015 | 02:03 PM
tr59210's Avatar
#3 on link below:
Yes, I bought the Denso Kit from Amazon with the strainer and I think it was a bit cheaper than Rockauto. ~$68.
I also bought the Beck Arnley fuel filter also and the Fuel Tank Seal. I think I'm set!
Yeah, I went ahead and bought the filter anyways and will replace it along with the pump since they're both in the same location.
Old Nov 8, 2015 | 09:27 PM
hitek9's Avatar
j35/6 Speed Swapped
Check your ground cable that goes from battery to trans. Gave my dad's CL starting trouble for a little bit.
Old Nov 8, 2015 | 11:49 PM
01acls's Avatar
Why would you not change the filter if you are changing the pump?
Any preventive maintenance that can be done with little to no additional effort will pay dividends in the long run.
Old Nov 9, 2015 | 01:57 PM
tr59210's Avatar
Thanks, I'll take a look. Although I've looked at that cable before, I didn't find anything out of the ordinary.
You're right. I changed the filter along with the pump on the weekend. Works great now! Faster/stronger startup. Only reason why I was asking was because the filters on our cars are considered "lifetime" filters and don't need to be changed. I couldn't find it locally unless it was over priced. I ordered mine online.
Thanks everyone! Now onto engine mounts!
Old Nov 9, 2015 | 02:22 PM
01acls's Avatar
Glad you got the car working again.
When it comes to filters there's no such thing as lifetime. Only flow rate or flow efficiency.
Once the filter gets clogged up then pump will burn out bc it's liquid cooled or the pump will loose pressure from partially clogged filter. Either way it comes back to failing pump. Whether it's actual or perceived. Once pump is out replace everything.
tj19855
23
Jan 28, 2016 07:19 PM
redash
Nov 13, 2015 07:09 PM
WRXtranceformed
1G RDX (2007-2012)
Nov 3, 2015 11:57 AM
unoccurring
Nov 1, 2015 11:33 AM
sh0tgunzshellz
Oct 31, 2015 01:13 PM
