Replacement bulbs for driving lights
I am kinda new ( had my type s for about a year). Want to replace
the bulbs in the driving lights ( fog lamps).
Should I get the Polarg m6's. ????
Are they easy to install. Autocarparts.com has the pair for $17
Re: Replacement bulbs for driving lights
Calling AztecRol or Scooter for help
Re: Re: Replacement bulbs for driving lights
Let me start by saying this, use the search button!!!
I am not trying to be mean, but it will be said, and I figured I would get it out of the way!!!
Here is a link to the thread that will answer all your lighting questions!!!!
=====> CLICK HERE <=====
There are two websites in there that have cheaper prices for bulbs!! I use www.optauto.com. Scooter uses www.autobulbdepot.com
READ THE WHOLE THREAD!!! There is a lot of good info in there!! I even have pics of some of the lights compared to stock.
If you have any more questions, post them in here.
Scooter or I will be happy to answer them!!!!
i got my polarg M6 for 12 bucks a pair....mine, didnt fit in the hole for the light housing so i had to use a Dremel and grind out the hole to make it bigger for that big bulb to fit through....if you dont want to grind the light housing, beeee careful, im not sure if that bulb would have gone through, but it seemed reeeeally tight, and i didnt want to bust it...so i just ground the hole open a bit more and no problems, then harness still locks in place as it should so no harm done
Re: Re: Re: Re: Replacement bulbs for driving lights
Originally posted by Scooter
if i had a nickel for every link that asked a road lamp/bulb question, i swear...
mada51589
Jan 9, 2025 04:40 PM
wusty23jd
Sep 24, 2015 11:41 AM
