Removing headlight housing
Old May 30, 2009 | 02:13 PM
gir_htx's Avatar
does anyone know how to take apart the housing?
Old May 30, 2009 | 02:52 PM
civicdrivr's Avatar
Heat. Melt the glue then pry it apart.
Old May 30, 2009 | 03:23 PM
Rajca's Avatar
wham bam thank you ma'am
stick in oven for about 15min at 225-250 degrees F. get some thick gloves (not the rubber ones) and pry the tabs loose then pry the whole thing open. its a lot easier with two ppl. one holds and cleans the glue and the other one prys them open.
do what u need to do, then put both pieces together and try to lock the tabs, then put back in oven for about 5-10 min at the same temp as before. when u take them out of the oven, press them firmly together for a few minuets so the adhesive can cool down and stick, recheck the tabs to make sure its all tight.
and hope for no leaks.
Old May 30, 2009 | 04:10 PM
gir_htx's Avatar
thanks!
Old May 30, 2009 | 06:23 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
+1.
if u want to, try removing all the glue and re-seal it with the same glue used on windshield. I heard this worked the best.
My headlights started leaking in heavy rain. I used teh original glue.
Old May 30, 2009 | 10:00 PM
Rajca's Avatar
i used the original sealant in all the head light i take apart, and so far, i have had no problems with any of them
Old May 31, 2009 | 07:29 PM
MrFluffy's Avatar
To many cars in my garage
15 minutes it was more like 5 for me
Old May 31, 2009 | 09:57 PM
dave586270's Avatar
Chamorro
Yeah everyone likes to use the oven. I wasn't too fond of the idea so i used a heat gun. Same premise, but a little more control. I used one when i clared my headlights:
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/d-i-y-clearing-headlights-495390/
cycdaniel
Dec 17, 2019 10:58 AM
scionxb3003
Oct 2, 2015 05:50 PM
pistacio
Sep 26, 2015 09:45 AM
JnC
Sep 11, 2015 06:06 AM
