Remote Start - Where is the stock alarm module and key sensor?
3-piece FTW
Okay, I just installed a dei remote start and I was wondering if anyone knew where the key sense or the stock alarm module is. Whenever I remote start my car, I can't unlock doors while car is on. I've read around and some places have said it's under the seat, but i can't seem to find it. Just looks like a plug for the power of the passenger seats.
I need to solve this problem by disabling the key sense where when the car is on tricking the car to thinking the engine is not on / key not inside the ignition so I can still unlock and lock my doors. Does anyone happen to know where the stock alarm module is or which wiring is the key sense?
Alarm experts please help. Thanks in advance!
Audio/Video/Alarm Expert
how did you do this alarm and remote start.
If you want to disable the factory alarm all you have to do is program your alarm to unlock before start and re-lock after start
tell me which dei unit you installed.
There is only one way to integrate the factory alarm with any alarm/starter and that is in the drivers door.
Blue/white Ignition switch harness -
TRANSPONDER IGNITION
Yellow/black At 7-pin plug on Ignition switch assembly +
TRANSPONDER DATA 1
Red At 7-pin plug on Ignition switch assembly DATA
TRANSPONDER SYNCHRO
Blue At 7-pin plug on Ignition switch assembly DATA
TRANSPONDER GROUND
Brown/black At 7-pin plug on Ignition switch assembly -
? Vehicle notes
PLEASE NOTE: This vehicle is equipped with TRANSPONDER chips in the ignition keys. This will need to be bypassed for Remote Starter installation. A keyless bypass module may be available, contact your distributor to find out. If one of these modules is not available to you, see the appropriate security diagram for bypass instructions.
* Accessible on passenger side of dash when door is open. The lock wires are found in a 22-pin BLUE connector.
** This wire will unlock your door if you disarm for remote start and you will need to pulse the lock wire to re-lock the doors after the vehicle is running. A BLUE wire (disarm only) can be found by going into the driver's door to the door module. This wire will disarm without unlocking the doors.
*** The PCM is located under the front passenger side footrest.
TRANSPONDER DATA 1
TRANSPONDER SYNCHRO
TRANSPONDER GROUND
? Vehicle notes
3-piece FTW
I have already disarmed the factory remote. I need to disarm the key sense to let the car still unlock while the engine is on. Nismo, do you have an AIM screen name?
i don't know if you've resolved this issue but you need to add keyless entry to your new key fobs that do remote start, if you disable keysense, your vehicle will not start. or stay running.
cycdaniel
12-17-2019 10:58 AM
HeloDown
09-08-2015 06:51 PM
