Remote Start Alarm Install
Old Dec 5, 2005 | 03:44 PM
rchurchman's Avatar
I know this is an Acura Forum but I'm hoping you can help me out.
My girl has a 97 Civic EX with the with the factory alarm (connected above factory deck) with keyless entry.
How do I can around that to install and aftermarket alarm/remote starter? Just unplug the alarm module above the facotry deck and leave it unpluged?
Also, what are the wire color codes for this vehicle?
Old Dec 5, 2005 | 03:50 PM
phipark's Avatar
Not Asian
Try the A/V forum or try a honda forum.
Sorry, can't help you.
Old Dec 5, 2005 | 04:54 PM
ccannizz11's Avatar
My Work is Done Here
pay a professional?
Old Dec 5, 2005 | 07:36 PM
RMLatinplaya's Avatar
Masshole
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 1997 / Remote Start
[PRINT THIS PAGE]
Item- Wire Color- Polarity- Location
12volts white (40A) + ignition harness
Starter black/white + ignition harness
Ignition black/yellow + ignition harness
Accessory yellow + ignition harness
Second Accessory white/black + ignition harness
Power Lock green/white - driver kick, blue plug
Notes: Also found in the green factory alarm plug located behind the radio.
Power Unlock green/orange - driver kick, blue plug
Use blue/yellow to unlock the driver door only.
Parking Lights+ red/black + driver kick, fuse box
Notes: Male blade terminal at fuse box. Also at the back of the dimmer switch.
Door Trigger lt. green/red - factory alarm plug
Can also be found in a light green plug above the fuse box or bottom of driver kick, harness to rear.
Trunk/Hatch Pin blue/black - driver kick, harness to rear
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Tachometer blue ac test tachometer connector
Notes: Driver side fire wall under hood.
Brake Wire green/white + brake pedal switch
Horn Trigger blue to gray - steering column
If you lock it with the factory remote you must unlock it with the same. You can leave the factory alarm plugged in, just dont activate it when you want to remote start the car. Or just unplug it all together
Old Dec 6, 2005 | 10:51 AM
rchurchman's Avatar
Ok then. Can I just unplug the harness in the back of the factory alarm and leave it out? Will the radio still work?
Also, I want the remotestart/alarm remote to control the keyless entry in the car. So as long as I hook up the unit to the correct wires, I can leave the factory one unplugged and use the new one?
Old Dec 6, 2005 | 04:15 PM
Masshole
Yeah, you can unplug it and use the wires
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
jordanboi
Sep 5, 2015 01:33 AM
datadr
Sep 2, 2015 06:46 PM
