Remember all the sunroof problems? Well....
Old Jul 16, 2001 | 07:59 PM
Tom2's Avatar
Unregistered Member
.... people were complaining about the sunroof noise while it was open, right?
My Mom's '00TL has developed an annoying sunroof noise ONLY while it's closed. I haven't looked at it yet, but it sounds like a creaking/groaning sound. Every time she hits a bump, even a tiny bump, the sunroof creaks/groans......
Maybe the rubber parts (seals/weatherstrip) are starting to dry out?
Anyone have any similar experiences?
Old Jul 16, 2001 | 08:17 PM
SidVicious's Avatar
Ambidextrous Masturbator
Originally posted by Tom2:
<STRONG>.... people were complaining about the sunroof noise while it was open, right?
Anyone have any similar experiences?</STRONG>
Yes (assuming it is the same sound that we hear in our CL-S'). This has been discussed at length. The sunroof needs an application of Acura Magic Tape. There has been a service bulletin issued for this problem for the CL.
Old Jul 16, 2001 | 08:24 PM
Wyle E. Coyote's Avatar
ACME sucks!
Yeh, it's the same sound I have. I used to have rattling but the dealer fixed that. This new noise is definitely rubber-based and seems to me more prevelant during warmer weather.
I'll get my dealer to look at it when I go in for the 15k check up.
Old Jul 16, 2001 | 08:30 PM
Tom2's Avatar
Unregistered Member
Originally posted by SidVicious:
<STRONG>
Yes (assuming it is the same sound that we hear in our CL-S'). This has been discussed at length. The sunroof needs an application of Acura Magic Tape. There has been a service bulletin issued for this problem for the CL.</STRONG>
But wasn't that problem for OPEN sunroofs? I didn't follow all the past threads, but I don't remember people complaining about noisy sunroofs that were CLOSED.....
Does the service bulletin pertain to closed sunroof problems?
Old Jul 16, 2001 | 08:32 PM
mffdvr's Avatar
Most definately take it to the dealer and have them apply some Honda Magic Tape....should fix your problem right up!! Did mine. I thought it was a rattle in the back parcel area....NOPE....it was the damn sunroof. Annoying but easily fixable. They'll be more than happy to help you out.
Tom2's Avatar
Unregistered Member
MikeN,
I haven't noticed people complaining about this, have you?
I know the rattling sound was a big issue, but this seems to be less of a problem.....
Old Jul 16, 2001 | 08:42 PM
gavriil's Avatar
Moderator Alumnus
<STRONG>MikeN,
I know the rattling sound was a big issue, but this seems to be less of a problem.....</STRONG>
Tom I have this problem. No prob when the sunroof is open. When it is closed and it is more 75 degrees out, man that thing squeeks. Very, very annoying. I've had this prob soon after I got the car but then winter hit and the prob stopped. Now it it is back with a vengance. Triple the squeeking than when it was new.
Old Jul 16, 2001 | 08:48 PM
HellaWhat's Avatar
*Hella* isn't a word.
GGuys, i don't want to sound like a broken record but I gits a question for you all. Is this related to the Wind deflector boucing against the other piece of plastic which in turn generates an annoying noise? I have a fairly recent built CL (05/01) and was wondering if this was the same problem.
Old Jul 16, 2001 | 08:56 PM
mffdvr's Avatar
Hey...like I said....a little Magic Tape'll do the trick. When you say Wind deflector do you mean the little deflector or the one you add as an extra?! It certainly shouldn't be the latter. It could be the small one, and I haven't looked to see where they applied the Magic Tape, but if you do that.....you'll fine. PROMISE. I've read tons of threads that have had the same issue and the Tape cured ALL!!
Old Jul 16, 2001 | 09:15 PM
mdaniel's Avatar
<STRONG>
Does the service bulletin pertain to closed sunroof problems?</STRONG>
Its when the sunroof is closed, but the hand operated shade is open. I guess the sunshade blocks enough of the sound that you can't hear it when its pulled closed. Acura magic tape took care of my problem. Unfortunately my rear deck rattle returned when I had the windows tinted.
Old Jul 16, 2001 | 09:31 PM
fastdriver's Avatar
Fastdriver
The TSB is for the squeak with the sunroof closed and the shade open. The fix is the clear tape that the dealer applies.
However, I would venture to say that if you use Zaino and apply some Z2/Z6 on the little 1/4 inch lip that you can see when the sunroof is tilted up, the squeak would disappear. Try it and post back here.
Old Jul 16, 2001 | 10:46 PM
crrink's Avatar
The problem when the sunroof was open was a loud buffeting or booming sound which some members likened to a helicopter trying to land on your car. There's a seaperate TSB for that - the dealer will adjust the little metal deflector that pops up when the sunroof slides back.
The squeaky-when-closed problem is much more prevalent for us.
I just had mine fixed, but the freaking thing still makes noise. Less noise, but still annoys.
Stupid dealer told me this was as good as it gets and that I'm too picky.
Bastard.
Old Jul 16, 2001 | 10:51 PM
cl-driver's Avatar
I'm confused. So there's 2 TSB's?
Old Jul 16, 2001 | 11:08 PM
CanadianTypeS's Avatar
I can only comment on the sunroof-closed-sunshade-opened squeaking. Mine was rattling and squeaking something fierce. Then the dealer applied the tape aroung the edge on the roof opening and it's been quiet as a church ever since. The car just feels a lot tighter.
Old Jul 16, 2001 | 11:26 PM
Jayru2's Avatar
Here's what's going on with Acura Sunroofs..
#1 When driving between 25-30 and another higher speed(forgot) WITH THE ROOF OPEN, the metal wind deflector will make a loud booming noise (almost like BAss from your woofers) This in ONE of the reported COMMON problems
#2 When the moonroof is CLOSED and the sunshade is open, you will hear the glass squeeking between the rubber seal and the glass. This cam be tested by simply pushing upward on your moonroof and hearing for the noise. This seems to be the bigger of the two problems. Some people have reported using greese, some tape. Some even have had their glass replaced. I would simply bring it into acura and DEMAND they fix BOTH #1 and #2 problems, since this is probably on ALL ACURAS ever made recently. It is a designers flaw!
Hope this helps/clears things up a bit.
Old Jul 17, 2001 | 01:15 AM
cl-driver's Avatar
Thanks Jayru2. I have problem # 2. If the sunroof is opened I hear rattling on bad roads but if i push the sunshade all the way back, the noise goes away. I never experienced problem # 1. Maybe because of the sunroof visor.
Old Jul 17, 2001 | 02:20 AM
ACME sucks!
Originally posted by gavriil:
<STRONG>
Tom I have this problem. No prob when the sunroof is open. When it is closed and it is more 75 degrees out, man that thing squeeks. Very, very annoying. I've had this prob soon after I got the car but then winter hit and the prob stopped. Now it it is back with a vengance. Triple the squeeking than when it was new.</STRONG>
100% correct! I got the "rattling" fixed in February and the car was quiet as a mouse until late April when it got kinda hot one day. A couple of days later (with cooler weather), no noise. Then summer came and now there is noise all the time when its closed. If I push up on the sunroof (when its closed), no noise. It's definitely the rubber molding around the sunroof. And yes, there is a service bulletin out for this.
For right now, I just turn up the music!
Old Jul 17, 2001 | 02:23 AM
ACME sucks!
Originally posted by HellaWhat:
<STRONG>GGuys, i don't want to sound like a broken record but I gits a question for you all. Is this related to the Wind deflector boucing against the other piece of plastic which in turn generates an annoying noise? I have a fairly recent built CL (05/01) and was wondering if this was the same problem.</STRONG>
Nope. I have this problem and I don't have a wind deflector, neither the pop-up one nor the the exterior one.
Old Jul 17, 2001 | 02:24 AM
ACME sucks!
Originally posted by mdaniel:
<STRONG>
Its when the sunroof is closed, but the hand operated shade is open. I guess the sunshade blocks enough of the sound that you can't hear it when its pulled closed. Acura magic tape took care of my problem. Unfortunately my rear deck rattle returned when I had the windows tinted.</STRONG>
I can hear it when the shade is opened or closed. It's just louder when the shade is opened.
Old Jul 17, 2001 | 02:27 AM
ACME sucks!
Originally posted by crrink:
<STRONG>The problem when the sunroof was open was a loud buffeting or booming sound which some members likened to a helicopter trying to land on your car. There's a seaperate TSB for that - the dealer will adjust the little metal deflector that pops up when the sunroof slides back.
Bastard.</STRONG>
I had this problem too. They removed my opo-up deflector and no more problems.
Old Jul 17, 2001 | 03:46 AM
HellaWhat's Avatar
Okay, I'm gonna venture and say that they prolly fixed this as my car has a build date of 5/01... The annoyance is all I have, where the small internal wind deflector *chatters* when wind hits it.
Old Jul 17, 2001 | 05:12 AM
oonowindoo's Avatar
no matter my sunroof is open OR closed.... it always rattles.....
Old Jul 17, 2001 | 05:36 AM
HellaWhat's Avatar
I dont hear anything but the engine when I drive around...
Old Jul 17, 2001 | 02:04 PM
RandyMax's Avatar
Sunroof Squeak:
Service Bulletin Number: 00032
Bulletin Sequence Number: 155
Date of Bulletin: 0011
NHTSA Item Number: SB615579
Make: ACURA
Model: 3.2TL
Year: 2001
Component: STRUCTURE:BODY ROOF
Summary: ON ALL 1999-01 3.2TL, 2001 3.2CL AND 2001 MDX MODEL VEHICLES, THE MOONROOF SEAL SQUEAKS AGAINST THE ROOF WHEN THE GLASS IS CLOSED AND THE SUNSHADE IS OPEN. *TT
Booming (Early production CLs and TLs only):
Service Bulletin Number: 00023
Bulletin Sequence Number: 139
Date of Bulletin: 0007
NHTSA Item Number: SB613943
Make: ACURA
Model: 3.2TL
Year: 2001
Summary: A CONDITION MAY EXIST WHERE A BOOMING SOUND IS HEARD WHEN DRIVING BETWEEN 20 MPH AND 40 MPH WITH THE MOONROOF FULLY OPEN ON VEHICLES FROM VIN 19UYA4 ... 1A000001 THRU 19UYA4 ... 1A007800. *TT
For the last time, can someone please copy these to FAQ?? That is, if FAQ still exists. I can't seem to get to it!!! #@$@#$!!
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
4drviper
Sep 23, 2015 07:42 PM
eastcoastguy
Sep 23, 2015 06:29 AM
