red line water wetter
Living in Michigan, are you wanting to destroy your car??
To answer simply, NO. Just run the normal 50/50 ratio of coolant and water and then add a bottle of WW.
Lead Footed
Easy, at the base of the radiator there is a drain valve which is easy to get to. Just take the rad cap off and open the valve. But refer to the manual to be sure.
Lead Footed
Mine's low too so I had to lift it enough to put a drain pan under it.
But it's easy enough. The drain valve is on your left when facing the front of the car. There's a smallish opening that you can feel a cock valve. Just twist it open and let a little some out.
I just had to do this again to add the Mugen cooling upgrades Scalbert noted in the past.![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Thanks Scalbert.
I think this is a must for folks in the south and or those that run their cars hard or in stop-and-go traffic.
Ruf
Thanks Scalbert.
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
Ruf
Lead Footed
Originally posted by darrinb
k, i'll c if i can get under there, i dont have anything to lift my car up with
Ruf
Lead Footed
Originally posted by civic4982
I'm thinking about adding the redline water wetter too... how much is a quart?
Ruf
Lead Footed
ruf: wanna help me do the redline tonight maybe?
It's about $7 with tax. And it should only take us about 15mins.
Ruf
Lead Footed
Originally posted by johntypes
If you go on web. site in order to work ,you must use it only with water.
read the fine print all of the brands say the same thing
Straight from the manufacturer:
Temp readings with:
Just a 50/50 mix = 228 deg
50/50 mix with WW = 220 deg
Water only = 220 deg
Water + WW = 208 deg
It also states that you gain improvements as you lower the ratio of antifreeze.
Ruf
Lead Footed
ooo... I'll wait to flush out my whole system then.
Ruf
how long can you keep the water wetter in your coolinf system?
i just added the water wetter in my reserve tank. no flushing done.
my car only has 11,000 miles on it when i put it in.
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
STL TL-S
09-23-2015 08:52 PM
