re transmission cooler
would installing a transmission cooler void the ext warranty on our cl, my cl-s has 88k. thanks
are they expensive? and the installing them too?
Originally Posted by GreenMachine
No they will not void the warranty, it's pretty easy.
Not expensive at all.
Search on Ebay for Hayden, that's what I purchased.
Search the FAQ for a DIY.
THANKS ALOT MAN.
Originally Posted by LUTHOR-CL
So Where Else Can I Get A Tranny Cooler Besides Online, Any Out Here In Ny? Thank You.
I Called An Acura Delaership Today, And They Said That I Would Have To Use An Acura Transmission Cooler Part And That I Cant Sue Any Aftermarkets Coz It Will Void My Warranty. And He Said That They Dont Make One For The Cl. Is That Really True?
Originally Posted by gaping46and2
Btw, Green, do you notice any difference with the cooler to w/o it?
I put on the comp tech cooler because it was a known fit,,, since I have seen others for a lot less,, I think it was $130 vrs $50. I put it on at 45k mark,, trans went out at 86k mark,, no problem with warrenty,, they put on a new trans and connected the cooler back up,, car is now at the 114k mark,,, I change out my trans oil every 20k,, I do the drain 3 qts and add amsoil syn trans oil,, which I have used since the first 5k mark.. I believe the trans design was bad,,, they now have changed it to a new a improved trans,,, on the 2007s...
If the trans is running cooler that can only be agood thing,,, hard to say if it does any good at extended the bad trans design life,,,
The cooler makes good sense, particularly on modded cars because all things being equal, excessive heat will shorten the life of any tranny, and more HP = more heat.
However, it will not prevent the demise of one of our craptacular trannys, because they have far bigger problems (design and material issues).
As for the warranty, the Magnusson Moss Act says that they (the manufacturer) can't refuse to honor the warranty unless they can prove the modification was the reason for the failure.
Some dealers reason that since you cut the lines and messed with it, any failure is on you. Not an entirely unreasonable position. But off the record most of them agree that coolers do no harm and might do some good, so long as they are installed correctly...
I have a tranny cooler sitting at home waiting to be installed, but instead my tranny decided to bite the dust today. At least I think it's the tranny. Anyway, does anyone have a direct link to the 109k/7 years 9 month exteneded warranty? I did a search and I found threads on it but not a direct like to the actual letter or info that was sent to owners. Anyone?
Originally Posted by pits200
I thought that they can't refuse warranty work on your new car. Like if you buy a car with a 4 yr 50K warranty, according to the Magnusson Moss Act, they can't refuse you the 50K warranty work. But as for the Tranny warranty, that is an EXTENDED warranty and I thought that plays into the picture a little bit if they want to be a prick.
But I bet that any dealer would gladly install a cooler without voiding your warranty, unless they were real a$$holes.
My only concern is that after the oil jet retrofit is installed, the return flow is split, with part of the flow going to the oil jet and the rest into the trans case. I wonder if they could say that the added hose/backpressure of the cooler changes the amount of ATF that is diverted to the jet and claim that it caused the failure
Since I have a blower, the cooler will be the least thing I have to worry about 'splainin' when the tranny frags
lanechanger
Oct 13, 2015 10:56 AM
the advance autoparts here has one for 29.99
every which way they can.
