ran a dyno today and threw 6 CELs
P0301
Cyl 1 Misfire
P0302
Cyl 2 Misfire
P0304
Cyl 4 Misfire
P0305
Cyl 5 Misfire
P0300
Random / Multiple Cyl Misfire
P1399
(i think this is a misfire code too)
i changed my plugs in december, may have overtightened but i don't think that would cause this?
here is the dyno: http://i40.photobucket.com/albums/e2...ancl/dyno2.jpg
Cyl 1 Misfire
P0302
Cyl 2 Misfire
P0304
Cyl 4 Misfire
P0305
Cyl 5 Misfire
P0300
P1399
how handsome I am
Originally Posted by CleanCL
gas mileage has been great, 250 a tank with an extremely heavy foot and all city driving, 300 a tank easily with heavy foot on the highway... shrugs, last month i got 400 to the tank on a long distance trip
P0301
Cyl 1 Misfire
P0302
Cyl 2 Misfire
P0304
Cyl 4 Misfire
P0305
Cyl 5 Misfire
P0300
P1399
Cyl 1 Misfire
P0302
Cyl 2 Misfire
P0304
Cyl 4 Misfire
P0305
Cyl 5 Misfire
P0300
P1399
Not Asian
would a bad cat make strange noises? i started hearing a rattle, sort of in the midlle of the car in the last week.
Former 6 speed crew
P0301
Cyl 1 Misfire
P0302
Cyl 2 Misfire
P0304
Cyl 4 Misfire
P0305
Cyl 5 Misfire
P0300
P1399
Cyl 1 Misfire
P0302
Cyl 2 Misfire
P0304
Cyl 4 Misfire
P0305
Cyl 5 Misfire
P0300
P1399
Former 6 speed crew
cel = censors(codes). ex--oxygen censor is not reading right (not enough oxygen gettin to the engine) a CEL goes off. Your ecu (brain) picks this up and ends up telling you there is something wrong by way of gauge light.
His misfires in his cyc. are do to the wrong combination of fuel, oil, air... combustion and in turn the cyc. does not fire correctly, again sending a message (CEL sode) to the ecu
each CEL code means a different problem like stated before, TypeR said 1399 means his cat. is not operating properly, so on and so forth
you read them by... im not sure about the CLS but for the honda prelude you connect to wires under the stereo and the engine light would blink a certain amount of times and at different rates giving you a numer of which CEL youd had thrown (ex. 1399).
im rambling....
im rambling....
Maybe your plugs are not the correct heat range, or something's wrong with them, or the coils. To get misfires on almost all your cylinders, & have it intermittent points to the plugs or coils. The cat code could be related. Or could be bad now because of the misfires.
If it was a rod or cylinder damage, it would be consistant, & your MPG would have dropped.
im rambling....
im rambling....
T&R Racing
Queens, NY
PM me for phone#, don't wanna mess with moderators.
They build rotarys (RX7s) but there is a guy, Dusty, who KNOWS honda engines, I've seen his work in person. I am probably going to let them do my 3.5L stroker. He estimated at a week if I had all the parts.
$75 for 3 runs w/ AFR, a bit pricey but in NY that's not bad.
Queens, NY
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
