quick little convienant mod
So i did the vsa delete a while back successfilly and always wanted to figure out a way to have the traction control switch turned off when you start the car. Well i did this, sorta. I wired a seat belt wire to the vsa switch soo when you plug in your seat belt, it turns off traction control...i know, kinda half assed but i am satisfied. Under the driver seat there is a blue/red wire in the center of the clip i ran a wire from there to the wire connecting to the vsa switch that is orange / whie i believe. I will provide pics if anyone is interested....
Yes as soon as you buckle your seat belt it turns it off......you can also make a 555 monostable timer which, is complicated but would be the correct way to do it. The vsa switch when you push it it sends a signal to the orange/white wire it doesnt connect a circuit.
And what a 555 monostable timer does is it gets an electrical signal when you start the car waits a few seconds and then sends an electric pulse out. Which is exactly what that slp unit is for firebirds/camaros which makes the traction control off when you start the car.
civicdrivr (04-19-2012)
Whats up with RDX owners?
Ive found the easiest way to disable TCS/VSA is to buy a 6MT.
![Teef](https://acurazine.com/forums/images/smilies/teef.gif)
justnspace (04-19-2012)
Why would a CEL pop up for removing a light bulb?
richardparker (04-19-2012)
InFaMouSLink
10-27-2015 06:52 PM
