question for you electricians
i'm thinkign about retrofittign a small profector fog light into my road lamp housings. if i spliced the wires with the original road lamp wires do you think it could handle 55 watt H3 halogen projector?? basically i'm trying to make sure they wont blow out.
Old&CnL
Carry a small extinguisher
Wiring is too small a gage, and the use won't handle it- a small set, 20-30 Watts, might be OK.
Just put in the PIAA 19224 18W bulbs, and they LOOK COOL!!!!!. My lenses may melt, but it's worth it!
Blown LS6!!
I have regular fog lamps mounted inside my plastic housings. They're 12v 55W. Anyway, I used the wiring that came with the lamps but I'm pretty sure they're a little thicker than the stock wiring. It isn't hard to just run a couple lengths of wire to the battery... I've had zero melting/heat issues with this setup. I DID have a little discoloration way back when I put the 18W PIAA bulbs in the housings. I think the fog light housings spit alot of heat out the rear through a couple slits. Go figure...
http://www.geocities.com/trohdy/Fogs.html
Thats the exact same setup i want to do Seattle but fit these in there or something like them
![](http://i17.ebayimg.com/01/i/03/62/1c/a7_1_b.JPG)
you think you could give me some wiring directions?
Do you guys think these would melt the housing?? if i glued them in at the black part??? or were you thinking i was going to stick just a bulb inside the housing??
Forget the housing...I'm sure they can be easily mounted like I mounted my hella micro de's
https://acurazine.com/forums/showthr...ighlight=hella
well i dont want a bunch of open space. and i dont think it would be hard to do at all. maybe if i made grills like yours i would mount them. whered you get the intructions for the TL switch hook up?? also whered you get the TL switch??? where are you located in MD??
I used the Hella micro de xenon foglights with oem switch, but I mounted them outside of road lamp housing in the lower grill. They come on when the road lights are on. . . has a nice effect with just the road lamps and fogs on.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
