Pulley information
Old 10-19-2008, 06:03 PM
loweredCL's Avatar
Question Pulley information
Someone posted a replay to a thread suggesting to add a light weight pulley to help give more useful power, but can't find the thread! If anyone knows that link and/or the link to the ebay listing I would greatly appreciate it!! Also, has anyone installed a crank pulley? There isn't much room there, how to you get into the space to change it!!! Thanks
Old 10-19-2008, 06:12 PM
666 Speed
artbran's Avatar
Pull off the pass. side wheel and its right there.
You can either the Option racing pulley (cheap and effective) or the Unorthodox Racing pulley (expensive and effective also)
Your choice. Both can be found on ebay.
Old 10-19-2008, 06:42 PM
ChucksCL-S's Avatar
This is a great mod that you'll feel every time you run thru the gears. The bolt that holds it on is REALLY tight, but a 3/4" impact gun or a really long breaker bar will get it off.
Old 10-23-2008, 09:20 PM
loweredCL's Avatar
Thanks guys, I will give it a shot....
Old 10-24-2008, 09:24 AM
Former Sponsor
Excelerate's Avatar
The Option pulley can be found on ebay. However we do sell the UR pulley; there is no need to go to ebay since AZ does have Official Vendors who support the site and can provide you with info and customer service.
Old 10-24-2008, 06:23 PM
loweredCL's Avatar
Hello, I went to the site and they had different pulley's. What is the difference between 50%, 32% and 15% underdrive?? Thanks
Old 10-24-2008, 07:29 PM
Former Sponsor
Excelerate's Avatar
Can you link me?
Old 10-26-2008, 03:48 PM
loweredCL's Avatar
Can you link me?
Here is where I was.
http://store.excelerateperformance.c...Make=UNIVERSAL
Old 10-27-2008, 09:52 AM
Former Sponsor
Excelerate's Avatar
Those are universal pulleys. Do you have a large stereo system (over 600 watts RMS) or supercharger? Or do you plan to get either? If so you want the stock size UR Ultra Sc pulley which is $230 shipped. If you don't you want the underdrive Ultra S pulley and here is the link to that part #:
http://store.excelerateperformance.c.../i-220257.aspx
Old 10-27-2008, 11:05 AM
Registered Abuser
immauser's Avatar
wow those pulleys are expensive... i was looking at the cheaper ebay ones which alot of people give good responses to
Old 11-22-2008, 08:57 AM
loweredCL's Avatar
I finally got my option pulley in and want to put it on today. Has anyone put one of these on before? Is it as easy at is looks? Loosen the belt, take it off, use the big breaker bar to get the center bolt off. I'm guessing you need to use a pulley to pull it off? Then work the pulley on, install the bolt, reinstall the belt, tighten the belt and rock and roll! Am I missing anything????? Thanks
Old 11-23-2008, 03:09 PM
Quarantuning
SlickShiftNall6's Avatar
Just did my pulley (UR) 3 weeks ago. Big breaker bar aint gunna cut it. Had mine up on a lift impact gun did nothing. Ended up needing to heat up the bolt with a torch before it would come off.
Old 11-23-2008, 03:12 PM
loweredCL's Avatar
Got another question. I compared the new option pulley and it is noticably smaller than the stock one. Do I have to get new belts? If so, what size??
emailnatec
29
09-28-2018 04:27 PM
c1souk
09-28-2015 11:20 AM
AmplifiedDetails
09-24-2015 02:55 PM
Quick Reply: Pulley information
