problems w/ front end
Texan trapped in NM
I recently put on some 18'' motegi racing rims and 235/ 40 yokes along w/ a few other mods on my ’03 CL-S w/ 6 speed. Well, the problem I'm having is over the last week my driver side front wheel was start to have a mechcanical grinding noise/ sensation. I took it to the dealership here in Albuquerque and the told me that everything looked fine mechanically. They deduced that the after market wheels were probably the problem. They told me that Acura had put out a bulletin in '02 stating that it wasn't a good idea to add after market wheels and tires to the CL-S and the TL-S. I had the Discount Tire take a look at the tire in question and they found nothing wrong with it. Has anyone ever heard of this before? I can't imagine how wheels could cause a grinding issue with the cars front driver side. Plus, it took a month+ with the tires before the issue started. I talked to Comptech and my local tuner shop and neither one have ever heard of adding wheels causing any kind of issue to the CL-S. Plus 90% of the folk on this web page have after market wheels.
Any help would be appreciated.
FYI here is a list of the mods:
Comptech Exhaust
Comptech Sway Bars
Comptech Springs
Neuspeed Front Strut Brace
AEM Cold Air Intake
On order/ waiting to go on:
Neuspeed Short Shift Kit
Magnaflow High Flow Cat
AEM Underdrive Pulleys
Momo Pedal Set
Comptech Exhaust
Comptech Sway Bars
Comptech Springs
AEM Cold Air Intake
Momo Pedal Set
Six Speeds
Originally posted by jruss1078
the wheels are +45 and the width is 7.5''
That offset # was supposed to be good according to Discount Tire computer.
http://www.motegiracing.com/
the tires clear fine. like i said the dealership checked it out visually and found nothing wrong.
Also, when I put the stock 17'' back on the problem went any.
Thanks for the words.
There's also that slight chance (depending on the style of rim) that the spokes may be grinding against the brake caliper. I've had that happen to me in the past with another car of mine where the offset was correct, but the spoke design interfered with the calipers. If the spokes cleared by just 1 more millimeter, the rims would've been perfect.
Texan trapped in NM
Did put the stock wheels back on an the problem when away. Then I swapped the 2 front tires to see if it was a particular tire. I haven't driven it much since I did this but, the probelm hasn't resurfaced. I'm just worried that it will come back at anytime. I can say for sure that it's not a pebble in the rotor, though. I really think that something is wrong with the bearings but, the dealership won't work on the car(under warranty) unless it's having the problem with the stock wheels on the car. They did offer to pul apart the front end at $85 on hr. Forget that!!! I guess we'll have to wait and see.
TLDude876
12-28-2016 03:18 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
