Problems programming TLS remote! Help!
Old Feb 9, 2002 | 12:13 PM
Marc S's Avatar
I printed out the instructions on Chod's FAQ. It says turn the ignition switch on to the 3rd position but it says you do not have to start the car. But the 3 position can only be reached when the car is started. Am i doing something wrong? And where exactly do you have to aim to hit the REC.? It also says to turn the ignition switch on and off, does that require going from I and II position? I tried this several times and whenever i had to aim the remote and hit the unlock button (i am supposed to hear the locks click) nothin happens. Am i just an idiot or is this a pain in the ass. Can someone help a brotha out?
Old Feb 9, 2002 | 12:23 PM
ChodTheWacko's Avatar
Moderator Alumnus
Re: Problems programming TLS remote! Help!
That is a typo.
You turn the switch to II, not III. It's the accessory position, where you haven't started the car, but it turns on the lights/nav/cd player etc.
You can aim the fob at the steering wheel.
The 'off' position is the position where you would turn the ignition to to pull out your key.
One note I also forgot is you have to wait 1-4 seconds every time you do something.
So turn ignition to II, (pause), push button, (pause), car off (pause), push lock (pause) etc etc etc
There are the steps made a bit more explicit:
http://www.acura-cl.com/forums/showt...hlight=program
Old Feb 9, 2002 | 12:48 PM
Samer007's Avatar
Smack My B*tch Up
I'd just chage the insides if you can not get it to program, alot easier, I could'nt get mine to program at all.
Old Feb 9, 2002 | 02:07 PM
Marc S's Avatar
Re: Re: Problems programming TLS remote! Help!
Originally posted by ChodTheWacko
That is a typo.
Thanks chod. I followed the instructions Shawn S posted and I got it in no time
Azonics
Sep 22, 2015 05:28 PM
GraveDigger
Sep 18, 2015 07:46 AM
GraveDigger
Sep 17, 2015 11:53 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
jordanboi
Sep 5, 2015 01:33 AM
