problem w/ speedbumps
Old May 4, 2005 | 11:16 AM
lilghettoboi's Avatar
Username fr High School!
Question problem w/ speedbumps
when i go over speedbumps sometimes, i hear a noise on the driver's side front wheel. When i tried lifting up my car to take look at it, the driver's side front wheel stayed on the floor, while the passenger front wheel was off the ground... I dont know what to buy to fix this problem... any suggestions will be greatly appreciated... THX IN ADVANCE!
Old May 4, 2005 | 11:26 AM
Bobbydoedoe's Avatar
I'm Cool
have you try lifting both side of the car?
Old May 4, 2005 | 11:36 AM
UNeeKLiNG's Avatar
did you try to lift up the driver side with a jack and the wheel stayed on the floor? your shocks could be blown or you forgot to put the nuts back on?
Old May 4, 2005 | 11:45 AM
ccannizz11's Avatar
My Work is Done Here
so you lifted from the center jack point and the passneger side came off the ground before the drivers side? Am I understanding this correctly?
Why don't you just jack up the drivers side and see if you can see where anything might be missing?
Old May 4, 2005 | 11:55 AM
UNeeKLiNG's Avatar
when my shocks were blown and i went over speedbumps, i heard creeking noises...and i tried pushing the car down from above the wheel, it would rise back up slowly as compared to a quick response from a good set of shocks
Old May 4, 2005 | 04:22 PM
yeah, i lifted both sides of the car, i didnt lift it too much just untill all the wheels were at least 2 inches from teh ground.... the driver's side front wheel stayed on teh ground though... maybe its the axel?
Old May 4, 2005 | 04:26 PM
JaredGMS's Avatar
Meat stick
make sure the top of the shock/spring assembly is attached to the frame
Old May 4, 2005 | 04:27 PM
Dan's Avatar
Dan
Confused
Originally Posted by UNeeKLiNG
. . . it would rise back up slowly as compared to a quick response from a good set of shocks . . .
??????????????? Seems bass akwards to me?
Old May 4, 2005 | 04:38 PM
philgates's Avatar
I hear a very low rumbling noise when i go over speedbumps
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
