pressure switch differences
Old Jan 2, 2019 | 07:14 PM
R.J's Avatar
R.J
4th Gear
Hello, have a 2001 CL-S with automatic trans 16000 km's on it, Was changing out the 3rd gear transmission pressure switch as blinking D5 light was coded as "bad switch" .
I ordered the switch correct number " 28600-P7Z-003 " and was sent a "28610-RKE-004 " this was from the Honda dealer. The colour is the same/black and connector the same but the body is not a "stepped" design but flat design and the "male" end with the threads is about 1/8 shorter and has no washer like the switch that I removed.
Just want to know if I should use this and add my old washer or leave it off ?
thanks :R.J
Old Jan 2, 2019 | 07:22 PM
https://www.oemacuraparts.com/v-2001...ensor-solenoid
According to this parts diagram, neither of those work for your car
28600-P7Z-013 replaces 28600-P7Z-003
28610-RKE-004 should be for MDX, TL, RL's, : https://www.oemacuraparts.com/oem-pa...ya-28610rke004
There is a
28600-RKE-004
that would fit your CL:
https://www.oemacuraparts.com/oem-pa...dXRvbWF0aWM%3D
Old Jan 2, 2019 | 08:42 PM
R.J's Avatar
R.J
4th Gear
OK, thanks for the quick response. I guess that I will reuse the old washer from the replaced pressure switch.
Old Sep 27, 2023 | 11:05 PM
Huskymaniac's Avatar
My car wouldn't start in park tonight but did start in neutral. It never did this before. I think it is this switch. The interesting thing is that I had the car sprayed with rustproofing spray earlier in the day. I wonder of the switch housing is no longer sealed and some of the rustproofing oil got into it. I am calling the local Honda dealer in the morning to see if they have the switch in stock as the car is already scheduled to go to my local shop for a ton of other work tomorrow. Timing belt, pullies, tensioner, water pump, passenger side radiator fan replacement, diff fluid replacement and a drain and refill on the ATF. Might as well do this too while it is on the lift. If not, I will have to order it and do it myself.
spydercatt
Jan 28, 2013 06:19 PM
macfubu
Feb 13, 2008 05:42 PM
chooker2001
Feb 3, 2005 01:11 AM
Wally
1G TL (1996-1998)
Jan 3, 2004 11:25 AM
