power plenum does it make a big diff??
Old Mar 19, 2009 | 10:11 AM
Drholiday's Avatar
B A N N E D
i was going to get one made and tb spacer from some shop mca here in miami for 200 bucks beats the p2r price just wondering if its worth it ???
Old Mar 19, 2009 | 12:35 PM
phee's Avatar
I got the Shifts
it gives you 700 hp. so does the search button
Old Mar 19, 2009 | 01:19 PM
fuzzy02CLS's Avatar
Not from my experience.
However I do dyno 250ish to the wheels with all my mods, so IDK if my car is a good indicator. I may have things setup different & gains may or may not be there for me because of that.
I thought I felt a difference, then I dyno'd after a week, & dyno'd the same numbers as before the install.
Old Mar 19, 2009 | 02:28 PM
CL6's Avatar
CL6
My only car is a Bus
Is that under the revised horsepower ratings?
Old Mar 19, 2009 | 05:11 PM
2Fast4you's Avatar
what are all the mods you got?
Old Mar 19, 2009 | 08:42 PM
fuzzy02CLS's Avatar
sig....
Add to it a Option crank pulley & the plenums.
Old Mar 21, 2009 | 10:56 AM
CLS6SpeedNupe's Avatar
sig....
I never understood why your numbers were so low, but I would just say that your dyno isnt a good indicator.
Old Mar 21, 2009 | 11:42 AM
nbennettksu's Avatar
i heart latin chicks
damn, I was worried about that... but you'd think mar air moar power...
Old Mar 22, 2009 | 12:54 AM
GRNMCHN03cl's Avatar
I thought it was for a better intial take off because all they do is store air its not like its pushing more air into your IM.
Old Mar 22, 2009 | 11:45 AM
Its all in your set up guys. Stuff like this normally work at full potential in a package. When I put them on my car the car was good but after I added my 3 inch cat back later it was a day and night difference cause the car was sick. You got to again look at the concept of the motor is basically a pump. The more effectively you can get more air into the motor and back out quick, the more power you will make. The Plenums are allow you to store more air to dump into the motor, but if you not flowing enough air into them or letting out enough exhaust then your not going to get the best results.
TL-Rocket
Apr 29, 2023 02:33 AM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
