post Icebox install problem, need some help
Old Oct 19, 2005 | 12:56 AM
belcom's Avatar
09 TL SH-AWD
I've installed the icebox this evening and when everything was done and over with I turned on my car and my left headlight is not working I haven't had a chance to check anything but here's what I observed on the way home from my friends house. I noticed that left turn signal blinks very fast when turned on, and at some point after about 20 minutes of driving the headlight turned on and the blinker also became normal. However I decided to check therefore turned off the lights and turned them back on and the headlight didn't come on again. When I turn on the HIDs I can see a very quick slight flicker and then nothing.
I did take off neg battery lead and installed the bracket that is required to hold the icebox.
So please tell me what happened? What did I do wrong? that shouldn't be normal.
Old Oct 19, 2005 | 06:21 AM
Type Sun's Avatar
Big up ya self, BO!
Same thing happened when I installed my Icebox. Problem went away after a couple of days and has worked fine ever since. Wouldn't worry, unless the problem doesn't go away after a week.
Old Oct 19, 2005 | 07:26 AM
belcom's Avatar
09 TL SH-AWD
I'm thinking it might be that ground wire from the fender. Probably bad ground and not enough current to jump start the ballast. It was kinda corroded when I took it off but I didn't clean it. But damn... it might something else. I can't imagine taking the top part of the icebox off again, the front bolt that holds it was a bitch to get in.
Old Oct 19, 2005 | 10:52 AM
Excelerate's Avatar
Former Sponsor
[QUOTE=belcom]I'm thinking it might be that ground wire from the fender. /QUOTE]
That's what I was thinking. I would double check that ground.
Old Oct 19, 2005 | 11:04 AM
typeR's Avatar
[QUOTE=Excelerate]
and if true may lend some credibility to a grounding wire set
Old Oct 19, 2005 | 12:56 PM
belcom's Avatar
09 TL SH-AWD
I noticed when the blinker is on, it blinks fast but very dim and the funny thing is that the left fog light does the same thing (blinks).
oook I just said the word "blink" too many times, and now it lost sense
Old Oct 19, 2005 | 07:14 PM
belcom's Avatar
09 TL SH-AWD
any more suggestions?
Old Oct 20, 2005 | 10:34 PM
belcom's Avatar
09 TL SH-AWD
it was the ground issue. headlight works fine now.
Old Jul 21, 2009 | 01:05 PM
tbiddie's Avatar
Where is the ground bolt. Under the airbox mount to the fender?
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Nitin
Sep 30, 2015 08:22 PM
NSolace
Sep 3, 2015 08:14 PM
NSolace
Sep 3, 2015 08:02 PM
