Please Help Rearview Mirror. How Do I remove It.
2000 Acura TL NGM
Hey my rear-view mirror is flooded and im scared is going to leak. i searched and searched and i cant find a good write up on how to remove it.
Can someone please explain how to do it. Thankyou
Chillin' in my trailer
Ok, here's how to do it. First, remove the map lights and sunglasses holder. This can be done by opening the sunglasses holder and removing the two screws and popping off the cover of the map lights and removing the screws in there. After that is loose, pull it down and unplug the rear-view mirror. After the mirror is unplugged, gently pull the rear-view mirror down toward the dash. Mirror should now be off.
Thank you AnthraciteBeast those scanned pages were really helpful! I had a terrible time getting my mirror off to put on a replacement until I read over those pages.
Okay, so I just got the old mirror off and a replacement mirror that I got from a junked CL installed, but now I have a problem.
The new mirror is really loose.. like, if I adjust the mirror, it wants to slide off the lug attached to the window, and into my hand. Did I install it wrong? I slide the replacement mirror back on by sliding it towards the headliner.
If it's just going to be like that, could I put a sealer or something around the edge of the bracket to snug it up to the mirror? If so, what would you suggest that wouldn't damage the window or the bracket?
Chamorro
Slide the mirror off of the windshield bracket and look at the metal 'rail' where the mirror mounts to the windshield. Using some pliers just squeeze/bend the rail so that its closer together and keep testing it on the windshield until its nice and snug.
I'm warning you now, you gotta put some real elbow grease into this, so don't think you'll just bend it real quick. Good luck, let me know how it goes
Thanks dave586270! I'll check out your method and see how it goes.
Chamorro
https://acurazine.com/forums/2g-cl-2001-2003-50/rearview-mirror-replacement-diy-724233/
I bet the rail that was suggested and the mirror was snug at first, but over the last few days has proceeded to slip off the window and dangle off the cable while I'm driving.
I'm sure I'm doing something wrong.. probably a stupid mistake. But can you be more specific. Do you squeeze the tabs on the back side of the mirror bracket closer together or pull apart? Or is it the little block looking thing attached to the window that needs to be squeezed? I've tried just about everything and can't get the mirror to stay put.
Chamorro
rockyboy
08-04-2024 10:35 AM
cycdaniel
12-17-2019 10:58 AM
chrisr
12-04-2015 02:17 AM
winkyyy
09-11-2015 04:40 PM
