Please Help!!!!!!!!!!
Old May 21, 2010 | 02:15 PM
mkshdy's Avatar
03 Acura CL 6SPD Factory Navi / bose system
I installed a pioneer d3 yesterday. We chg inputs to outputs on the harness and bypass the amp but still using the factory wiring for the new speakers. as far as audio everything works. now unable to access climate control on factory navi screen.
the car no longer reads the outside temp and when i activate the a/c by auto button manually the air conditioner just blows regular air it does not get hot or cold when i chg the degrees up or down
please my fellow acuraziners!!!!!!!!!!!!!!!!!!!
Old May 21, 2010 | 02:58 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Make sure nothing got unpluged and your wiring is correct.
I would run new wires for your speakers.
Are the wires your trying to tap into for your speakers going to the amp that your trying to bypass ?
Old May 21, 2010 | 03:03 PM
aznboi2424's Avatar
if the outside temp guage isnt reading, then something's messed with the wiring to the AC. maybe one of the harnesses got unplugged or something.
Old May 21, 2010 | 04:17 PM
mkshdy's Avatar
bypass the amp its not connected any more
i will go back and check to see if any thing is lose or not plugged up
any more ideas???????????????/
Old May 21, 2010 | 04:46 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
ask in the audio video part of the forum, you will get a better response there
Old May 21, 2010 | 04:51 PM
only factory wires I used installing my 2 din was both power wire and ground.
back wires I ran completely new.
Front wires I ran to the mutiboxes on either side of the dash to pick up the factory door wires.
No issues ever.
Start over would be your best response.
Old May 21, 2010 | 05:56 PM
civicdrivr's Avatar
Go over everything you touched. It shouldnt just stop working out of the blue.
Old May 21, 2010 | 07:26 PM
friesm2000's Avatar
B A N N E D
x2, but yeah either something got unplugged, or you blew a fuse or something, so again check your wiring
Old May 22, 2010 | 12:21 AM
mkshdy's Avatar
problem solved climate control plug was lose
