Pics of the Cold Air Box
Location: Somewhere between here and there, yet neither.
Well...here are the pictures for this thread.
http://www.acura-cl.com/forums/showt...threadid=53525
Originally posted by scalbert
That looks very nice!! But I think the prototype has a bit too much vacuum tubing length...
Originally posted by Mike
so where's the dyno? how much $$?
JRock - Those are the vacuum lines.
QuiteaTypeS - Yeah that's a dragon Intake....and it is pretty loud.
Twiggy - Sarah Wrap... That's a lexan shield on the cover....you think we should make it one window or keep it two???
Originally posted by JRock
Moo - what are the vacuum lines for? Is that some sort of water-intake-prevention device?
I forgot the need of these, but they are on the stock rubber connection between the VSA and the airbox. The intake shown just replaced them with silver one's, but they didn't add anything new in functionality.
There are various items under the hood that require vacuum sources/clean air. Although these are before the throttle body so they really dont have any negative differential pressure (vacuum) to them, any air lines under the hood are generally called vacuum lines.
They look nicer...
The dragon intake takes maybe 30 minutes to install....because of the removal of the bottom resonator box in the bumper....less maybe. The box will be closed off....the hot air seeping in is not an issue as hot air rises...the cold air in the box will stay cold as it draws from the bottom area of the bumper, much like the CAI, but without the risk of HYDROLOCK....AEM's water bypass seems like a good idea, but if not installed properly could still suck in water. The box is made by Weapon-R....this is a rough prototype...the new one will be made sometime next week or this week Friday...depends on when I have time to go.
Oh yeah...the carbon fiber is a really tricky thing to work with...it requires a lot of time....if you want the carbon fiber look..you can always order the overlay....and cut it yourself...
Retired Post Whore
Originally posted by ChodTheWacko
Okay, dumb question, is this cold air box made by Weapon R?
This isn't comptech's I assume?
BoricuaTL
04-08-2016 01:08 PM
