pcv valve?
pcv valve?
where is it located? i don't think i ever changed it ('01) and i don't ever remember having my dealer change it. how often should it be replaced?
Uses turn signals in my
haha I just changed mine tonight, my friend had an extra at Advance autoparts, so I figured why not. It costs $2-4.
Take off your plastic engine cover (4 bolts) and look for #2 in the diagram
how it looks like:
how it looks like:
What's wrong with your PCV? Are you getting high idle-speed? or Did you find Oil in your Airbox? You can also check it on idle by pinching the PCV hose going into the intake manifold. There should be a clicking noise.
CLos type Solis
My 01 CLS NAVI has 93K on it. PCV never been replaced. Is this important to replace and/or will it make much difference on fuel efficiency or performace?
i don't even remember making this thread. i must've had something wrong back then, but it probably corrected itself. now though, my check engine light is on and i'm having idle problems. i've already ordered a new iacv. should i change my pcv too? btw, i do hear this clicking noise under the hood.
Blown is Best
Originally Posted by srehmat02
I think if it doesn't rattle, it's broken right?
Blown is Best
Originally Posted by aznboi2424
any significance to replacing the PCV Valve?
It's good to check it ocasionally in either case.
Blown is Best
Strange thing about the PVC valve is that my dealer doesn't stock this item. This is usually an indication that it's not replaced very often. Parts guy thought I was nuts for needing to replace mine. I definitely had a stuck valve that needed to be replaced and when I explained my setup, he understood.
