Painted Brake Rotors
Old Jun 1, 2005 | 03:33 PM
cltphantom's Avatar
Seen a ton of posts on the calipers but nothing on the rotors. I've seen some on eBay with the option for gold or black rotors. Although I'm thinking that for $40 extra they'll eventually wear off. but at least the non-rub areas would retain their color (-dirt buildup). Anyone had experience/opinions (behave) with these?
here's a link to the ones i saw...
http://cgi.ebay.com/ebaymotors/ws/eB...category=33564
Old Jun 1, 2005 | 03:46 PM
falabarce's Avatar
$149 for a set of 4?!?!?!
I would be weary of purchasing these...
I just got a set of front cross drilled only rotors for $190 front and $150 rear...
For $150 they say they give military spec grade PLATING...but what about the metal they're using? I personally don't think that the metal they use is any better than stock rotors...
Old Jun 1, 2005 | 05:49 PM
1killercls's Avatar
GEEZER
I dunno..this is a damn good rating for EBAY
Positive Feedback: 99.7%
Members who left a positive: 945
Members who left a negative: 3
All positive feedback received: 972
Old Jun 1, 2005 | 06:16 PM
mclarenf3387's Avatar
Thats only tells you about the experience with the seller, not how they hold up after 10k miles of "spirited" driving.
I'd be wery as well
Old Jun 1, 2005 | 06:18 PM
Seattle Cl-S's Avatar
Blown LS6!!
I painted the edges of my rotors. I also painted the center section that the wheel hubs don't cover. Looks much nicer seeing black instead of rust. Took maybe 1.5 hours to do 2 coats on each of the 4 rotors. I used caliper paint (brushed)...can't remember the brand.
Just remember, to paint all the way around the rotor you need to have it spin freely. That means when you're working on the rear, the parking brake needs to be off. When on the front, the car needs to be in neutral and the parking brake on!! Block those wheels very well from both sides so it doesn't roll!!
Old Jun 1, 2005 | 07:33 PM
m&b6speed's Avatar
buy my car
would be sweet to have black rotors though.
i agree with everyone too, be weart. whats the warrantee/guarantee
Old Jun 2, 2005 | 11:22 AM
zoltanh's Avatar
I need a Hybrid CL-S
Those rotors dont look like they have the chamfered holes drilled in them, nor does it say they are chamfered. If the rotors arent chamfered they are more likely to crack under heavy braking. Dont get those perticular rotors, they are poor quility and you should always look for drilled rotors that have chamfered holes.
Old Jun 2, 2005 | 01:12 PM
AuCLSman's Avatar
had gold color, zinc plated slotted rotors on 01 for 5 yrs. (wisc. winters) when replaced reciently the zinc coating had completely rusted away. the plating wears off the braking surface almost immediately the remaining surfaces showed progressivly more deterioration after the second full winter.
Old Jun 2, 2005 | 01:56 PM
RaviNJCLs's Avatar
I am so confused. You're saying that they are good? And you had rotors that lasted 5 years? Is this correct?
Old Jun 2, 2005 | 04:25 PM
zoltanh's Avatar
No, what i got out of it is that the rotors suck ass.
Old Jun 2, 2005 | 06:36 PM
1killercls's Avatar
GEEZER
Good point. Like mine.
Old Jun 3, 2005 | 09:13 AM
AuCLSman's Avatar
post 9, i am pleased with the performance of the slotted / plated rotors considering they see heavily salted roads daily for 6 months each year. they were replaced due to wear , with new e-coated slotted rotors reciently. time will tell if the e-coating performs as well or better.
Jul 16, 2017 07:33 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
