P2R fuel rail
Old Dec 14, 2009 | 04:01 AM
Nersh7's Avatar
I Drive Like A Dick 8≈
P2R fuel rail
Looks like a new item from them
http://powerrevracing.com/store/inde...hk=1&Itemid=53
thoughts on it...
Old Dec 14, 2009 | 07:44 AM
phee's Avatar
I got the Shifts
looks good. but thats way too much flow for a NA without a tune. and our cars run rich from the factory. if anything; leaning out the tune a bit would yield more power. unless ur boosted
Old Dec 14, 2009 | 08:46 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
i dunno what the point is, it's underneath the manifold so u will no see any of the rails practically.
and then u'd need a FPR to regulate it since the flow is increased since pressure is decreased.. I could only see it causing problems VS solving problems.
Old Dec 14, 2009 | 09:59 AM
richardparker's Avatar
3.7L Nitrous Breathing CL
Those are a sweet mod.
Bigger fuel pump those rails and bigger injectors you will be able to feed our engines fully modded nicely.
Tune would be needed to maximize gains for sure.
Old Dec 14, 2009 | 10:02 AM
gnuts's Avatar
3.5 psi
well it's meant for guys who are boosted who want/need extra fuel. It doesn't matter if you can't see it. (it's not meant for show)
Old Dec 14, 2009 | 10:03 AM
for the price... it damn well better add to the appearance of the motor.
but either way it is pointless unless u are boosted heavily.
even w/o upgrading the pump u would be DUMPING fuel in, in comparison due to LESS pressure.
less pressure = more flow and viceversa.
Old Dec 14, 2009 | 10:15 AM
Even with them being 169 they would cost you $1000 + to get the most out of them.
rails,ecu,harness,fpr,injectors,pump.maybe even bigger lines if your trying to build rediculas HP
Those rails are just one piece to the puzzle.
I'm glad to see more and more being available for our engines
Old Dec 14, 2009 | 11:16 AM
yea I want suspension parts to come out for our CAR!!!
Old Dec 14, 2009 | 05:37 PM
friesm2000's Avatar
B A N N E D
saw them at vividracing.com like a week or two ago, but yes they are sweet and not many people will actually be able to use them to their full poitntial
Old Dec 14, 2009 | 05:38 PM
friesm2000's Avatar
B A N N E D
i want some nice aluminuim arms/knuckles to help reduce the unsprung weight
Old Dec 14, 2009 | 06:03 PM
Rajca's Avatar
wham bam thank you ma'am
its a cheap price. and i dont think u need a tune if u use the stock injectors. computer controls the flow.
try to get some custom made and ur paying $300+ easily.
Old Dec 14, 2009 | 06:22 PM
victorvu's Avatar
^ +1 thats cheap but i would only see this work if you're either fully built or boosted. otherwise theres no use for it.
Old Dec 27, 2009 | 07:05 PM
PowerRev's Avatar
These fuel rails flow a lot better than the stock fuel rails. We are running these fuel rails on our All Motor race car with great success. we have more steady fuel pressures, as the fuel rails flow a lot smoother than oem rail.
The price on the fuel rails are pretty good. A average fuel rail for a 4 cylinder engine sells for $119-$149, and that's only for 1 fuel rail, as these are 2 fuel rails.
This mod does require custom fuel lines, etc
After we put the engine back into the accord, I will take some pictures of our setup.
Old Dec 27, 2009 | 07:34 PM
friesm2000's Avatar
B A N N E D
not many people will have taken off their fuel rails and let alone looked inside
but as said before most people will only actually do bolt ons, so most people will not need them, but THANK YOU for making them for us more serious modders
also can you maybe go for adjustable cam gears next
Old Dec 27, 2009 | 10:15 PM
Rajca's Avatar
^what he said, but adj. cam gears are gonna cost a lot. not what an average bolt on guy is gonna get nor want to install them selfs
Old Dec 27, 2009 | 10:52 PM
LIPPSTUH's Avatar
Unregistered user
p2r, maybe you should make the fuel lines to go with the product.
Old Dec 27, 2009 | 11:06 PM
friesm2000's Avatar
B A N N E D
would be kinda hard with not knowing what type of fuel pressure regulater and such people would be running, and were it would be mounted, so too many variables
i guessing that they proably would have screw in pipe thread fittings, which you can easily get AN adapters for, or a barb fitting if you must
Old Dec 29, 2009 | 11:41 AM
civicdrivr's Avatar
Sean, Ill be contacting you in the a few weeks for these.
Old Dec 29, 2009 | 12:29 PM
sgmotoring's Avatar
Bleed Honda Blue
Here is my old post. Ran larger injector with 100 psi fuel pressure on stock rails (had to modify rails a little). I Had 3.5L, intercooler and 12 psi of boost. Eventually I had to stop adding HP as my transmission was breaking every few thousands miles.
https://acurazine.com/forums/2g-cl-2001-2003-50/my-newest-mod-458395/
Old Jan 26, 2010 | 07:53 PM
Rajca's Avatar
i bought these rail a few weeks back. nice craftsmanship and great product.
Old Jan 26, 2010 | 11:01 PM
Blazinaccord's Avatar
9th Gear
Rajca, have you installed the p2r fuel rails? If so, How do they feel compared to stock?
Old Jan 26, 2010 | 11:50 PM
Nersh7's Avatar
sweet
I dont know why this is my second reply to this thread considering I started it I tend to get side tracked lol
Old Jan 27, 2010 | 04:58 PM
friesm2000's Avatar
B A N N E D
would be absolutely no difference between stock and the hi-flow fuel rails, as long as the engine was getting the proper amount of fuel before hand
Old Jan 27, 2010 | 06:00 PM
Rajca's Avatar
ive installed them. easy installation, but not using them at the moment. still in teh building process.
Old Jan 30, 2010 | 08:21 PM
9th Gear
Okay thanks man for the heads up.
Old Feb 25, 2016 | 02:54 PM
NobleTL's Avatar
This threads pretty old but didn't want to start a new one and have been researching the p2r fuel rails. I've read some posts stating these are for boosted cars and improve the gas flow quite a bit! Currently I'm working on exhaust for my TL then going to do the j37 IM swap with TB and larger cai. Eventually I'll do the j37 forged crank, J37 forged rods and 05 RL forged pistons and rings. Are the fuel rails something at that point after those mods that would improve anything? Or for the price and since I'm not boosted are they a waste of money? Seems like a lot have these installed but have seen mixed reviews. Was hopping after 5-6 yrs more info would be available as more are doing j-swaps or since the j35's and j37's are out of there's a cheaper more beneficial fuel rail like an oem one.
Old Feb 25, 2016 | 03:37 PM
gnuts's Avatar
3.5 psi
not many have these installed. At least who post here.
My guess would be that if you're going to have an n/a 3.6 stroker down the road your stock setup would be fine. Are you planning on tuning? You would maybe benefit from bigger injectors (RDX) at that point but you wouldn't be needing the additional flow the boosted guys need for their setups.
Old Feb 25, 2016 | 03:47 PM
JarrettLauderdale's Avatar
The build thread on NSX Prime with the guy installing a J35 into an NSX mentions these. His experience was fairly negative as he had issues with the upper portion of the injector seating into the CNC-cut holes in the rails. He was using an OEM-style injector and his consensus was they were not really what the rails were designed for, but it didn't seem obvious that there would be a problem.
That said, I don't see a reason that you should have much of a need for something like that with your currect power goals for any reason other than a bling factor. Any fuel upgrades would need to be accounted for with a tuning solution, anyway. My recommendation would be to get a set of J30A4/5 or J32A3 (same part number as many early second-generation J-series engines) lower runners and fuel rails, six RDX injectors with pigtails and run those. As long as you're not going for a power levels over 400hp, that setup should suffice.
Old Feb 29, 2016 | 08:48 AM
PowerRev's Avatar
Hi
Its been quite some time since we last posted on here.
We have been selling a lot of these fuel rails to the swap car market. Guys with Civics and J Swaps. We sell at least 2 sets of rails per week.
So they have been working out good for most people.
We have designed the rails to work with a factory style injector only. So if going with aftermarket injectors, you need to buy a injector that's the same dimensions as the stock injector.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
joflewbyu2
Oct 8, 2015 11:16 AM
