p0132 error code WTF!?
Old Dec 20, 2007 | 08:43 PM
LIPPSTUH's Avatar
Unregistered user
okay i posted in this thread a few months ago: https://acurazine.com/forums/acurazine-clubs-meets-15/different-kind-meet-tri-state-191593/
now i thought it was my spark plugs b/c the check engine light and symptoms were off and on. so i just changed my spark plugs and now i still have the light.
i got this code when i ran the test/scan: P0132: 1: Primary HO2S Circuit High Voltage (Sensor 1)
what to do?
Old Dec 21, 2007 | 12:06 AM
srehmat02's Avatar
Did you try a new primary oxygen sensor?
Old Dec 21, 2007 | 12:47 AM
LIPPSTUH's Avatar
Unregistered user
*sigh* no, any reason for it to be "broken" anyone have the part number?
Old Dec 21, 2007 | 01:00 AM
srehmat02's Avatar
I have a used stock one.. I thought mine was bad, but I am have a feeling it still works fine, because replacing it didn't solve my problem. If you are local to me, you can try swapping sensors with my used one.. see if it resolves your issue.
Old Dec 21, 2007 | 01:28 AM
LIPPSTUH's Avatar
Unregistered user
what solved your problem? i don't get how the o2 sensor will affect my acceleration response... *shrug* i'll be back in irvine in january, i'll PM you then =P thanks for the offer man. if it solves my problem, i dont mind paying you for the part of course. thanks
Old Dec 21, 2007 | 01:41 AM
srehmat02's Avatar
Well if you have a bad primary o2 sensor, it throws your car into limp mode when the CEL is on, so it could affect your acceleration.
I haven't solved my problem, I think I narrowed it down to the fuel pump going bad, I will try replacing it soon, see if it works.
Just let me know man, you could come check out my blower at the same time, if its still available then
Old Dec 21, 2007 | 07:56 AM
fuzzy02CLS's Avatar
Replace primary 02 sensor, & problem swill go away.
Old Dec 21, 2007 | 12:48 PM
LIPPSTUH's Avatar
Unregistered user
thanks guys, i'll try srehmat02's o2 sensor. i'll check out the blower too =D
Old Jan 2, 2008 | 09:00 PM
LIPPSTUH's Avatar
Unregistered user
Old Jan 2, 2008 | 09:13 PM
LIPPSTUH's Avatar
Unregistered user
nevermind on the part number. i did a quick search online and there are universal ones... denso and bosh. which one is better?
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
