p0132 error code WTF!?
okay i posted in this thread a few months ago: https://acurazine.com/forums/acurazine-clubs-meets-15/different-kind-meet-tri-state-191593/
now i thought it was my spark plugs b/c the check engine light and symptoms were off and on. so i just changed my spark plugs and now i still have the light.
i got this code when i ran the test/scan: P0132: 1: Primary HO2S Circuit High Voltage (Sensor 1)
what to do?
what to do?
I have a used stock one.. I thought mine was bad, but I am have a feeling it still works fine, because replacing it didn't solve my problem. If you are local to me, you can try swapping sensors with my used one.. see if it resolves your issue.
what solved your problem? i don't get how the o2 sensor will affect my acceleration response... *shrug* i'll be back in irvine in january, i'll PM you then =P thanks for the offer man. if it solves my problem, i dont mind paying you for the part of course. thanks
Well if you have a bad primary o2 sensor, it throws your car into limp mode when the CEL is on, so it could affect your acceleration.
I haven't solved my problem, I think I narrowed it down to the fuel pump going bad, I will try replacing it soon, see if it works.
Just let me know man, you could come check out my blower at the same time, if its still available then
Jamus22
06-11-2023 10:08 AM
