overheating and fan noise? Help!
Old Dec 8, 2005 | 12:56 PM
locc_510's Avatar
Two issues on my 2001 clp. First when I'm in stop and go traffic, the meter that reads the temperature of my engine goes up and sometimes even reaches the red. Why is this? Another problem is that now when I turn off my engine, the fan continues to make noise for about 5-10 min, or at least I think its the fan, why is this? And what can I do to fix these issues. Any feedback helps. Thanks
Old Dec 8, 2005 | 01:39 PM
phipark's Avatar
Not Asian
Your fan stays on because your car is overheating. Replace your thermostat and see where that takes you. Make sure you also bleed the coolant.
Old Dec 8, 2005 | 05:10 PM
psychoRN's Avatar
RN are my initials...
yeah same thing happened to me, check your coolant levels. after i got my IAC valve replaced i think my coolant started burnign up.
Old Dec 9, 2005 | 08:21 AM
silvervtec96's Avatar
Back to a MT!
I had the same problem....car was overheating at stoplights....I checked the coolant over flow and it was empty, put some coolant in there and now its fine. Not sure why coolant would "burn up" but I think the dealer was working on my car and i might have lost some and they didn't replace it.
Old Dec 9, 2005 | 10:37 PM
tommy020's Avatar
just remove thermostat, or tell any mechanic to remove it and cut out the spring then put it back because you need the core with the rubber gasket, and forget forever about overheating. I did that to my car, and don't have anuy of that problems.
Old Dec 9, 2005 | 11:14 PM
ghost_masterCL's Avatar
doesn't that cause the coolant to flow constantly causing bad gas mileage, long warm up times, and more engine wear?
Old Dec 9, 2005 | 11:22 PM
tommy020's Avatar
long warm ups?? no it warms up faster. Just trust me on this, all of us being told that we must use a thermostat, they even made a mugen thermostat that opens at lower temps, but I went opposite direction and cut the spring out, everything is cool right now.
Old Dec 9, 2005 | 11:28 PM
tommy020's Avatar
any mechanic would probably tell you that you can't do it , and give you crap about why not to do it, they know as much as you about this thing(very little). I found that mode from real pro, not your everyday mechanic with a little knowledge about cars.
Old Dec 9, 2005 | 11:50 PM
RooEng's Avatar
Let's see... Somebody from Miami telling a guy from Denver "it warms up faster. Just trust me" hmmm.
Old Dec 10, 2005 | 12:07 AM
StypeCL's Avatar
Make sure the overflow hose is connected to the overflow tank!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
