Outside Temp Display
Old Apr 19, 2003 | 12:20 PM
Smitty's Avatar
Anyone know how to adjust the digital display?.. I know mine is wrong.. it is off by 7-10 degress...
Smitty
Old Apr 19, 2003 | 12:27 PM
Wayne's Avatar
I've experineced the same thing with mine.
Old Apr 19, 2003 | 01:35 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
while the car is running press and hold the 2 buttons ( Reset and Select) it will cycle +1 +2 +3 -1 -2 -3..
Old Apr 19, 2003 | 05:17 PM
Smitty's Avatar
yeah I did that... Which one do you stop on?... it goes -3,-2,
-1,0, 1,2,3... What do the numbers mean?
Smitty
Old Apr 19, 2003 | 05:30 PM
pianoman41's Avatar
Smitty
That's the number of degress it will adjust plus or minus. The most you can adjust is + or - 3 degrees. Also remember, the outside temperature gauge is not considered to be displaying an accurate reading until you are traveling faster than 35 mph and you are not following another car. Any other situation can adversely affect readings. Also, upon start-up it can take upwards of 10 minutes for the probe to acclimate and properly display the correct temperature. This is most noticeable if you park your car in the garage and then go outside on a very hot or very cold day. It may take up to 10 minutes before you get the true temperature reading.
Old Apr 19, 2003 | 05:31 PM
Zapata's Avatar
Cost Drivers!!!!
it adds or subtracts the digit from the temp it's displaying. So if your temp reads 70 and it's 73 then you need to hit +3. Get it?
Old Apr 19, 2003 | 05:52 PM
Happy CL-S Pilot
and you can repeat to adjust again.. -+ 3F at a time.
Old Apr 19, 2003 | 06:15 PM
Smitty's Avatar
AHHH...Now I understand... Thanks guys for the input..
I guess I need to go drive past one of those Banks that flash the temperature and see if I need to adjust...
Smitty
p.s. Extremely Useful topic here..
Old Apr 22, 2003 | 07:41 PM
flint's Avatar
You can only adjust +3 or -3 from what the gauge reads period. If it reads 73 and it is 70 you can adjust it to -3 and it will read 70. Now you are permantly adjusted to -3 of whatever it thinks it is outside. If you try and adjust more it will just go 1,2,3,0,-1,-2,-3 again and if you stop on -3 it will still read 70. It only has 6 possible degrees of adjustment.
Old Apr 22, 2003 | 09:45 PM
chikai's Avatar
trying to get a lil V-I
drive by Mellon...they've got a big flashing temperature sign on Grant street...
Old Apr 22, 2003 | 09:48 PM
Smitty's Avatar
thanx
ITSJESTER
17
Dec 6, 2018 02:29 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Jboat
Sep 30, 2015 10:58 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
Froid
Sep 27, 2015 06:16 PM
