Only one headlight working!
Ok I did some research before posting hoping to shed some light on this. Last night my driver low beam stopped working. Found that fuse for that light was blown (20 amp). Put a new one in and as soon as i turned the lamps on, **pop***, fuse done. I tried switching the relays to see if one went bad. Didn't change anything. The weird part is that when i turn the headlights on the passenger side high beam comes on too, with nothing lit up on driver side. If I unplug the low beam (HID) then everything but the low beam will work on the driver side...?
Everything connected:
Passenger
low beam - on
high beam - on
fog - on
Driver
low beam - off
high beam - on
fog - off
Driver low beam disconnected:
Passenger
low beam - on
high beam - off
fog - on
Driver
low beam - off
high beam - off
fog - on
Its really odd and driving me crazy. I'm thinking i have a ballast thats bad? I ran out of 20 amp fuses so i put a thirty in and the wire to the low beam started smoking! The turns still work so i know its not the mulit-function switch for the turns/headlights. Any help would be awesome...
Passenger
low beam - on
high beam - on
fog - on
Driver
low beam - off
high beam - on
fog - off
Passenger
low beam - on
high beam - off
fog - on
Driver
low beam - off
high beam - off
fog - on
mine is not as extreme as yours, but my driver side is doing the same thing and i have the DDM hids hooked up to the high beam plug, and it still does it. i have to flick it on and off till it comes back on..my fuses are great, so who the hell knows? its the damn hid ferry coming by and robbing the power....lol
Why would a bad ballast cause problems with the highbeams? My car is down to only 1 highbeam at night. The highbeams are in a weird running light more otherwise, even with the ballast unplugged altogether. Help!
Try installing a relay harness to get the power from the battery. My ballast went out and I just replaced both with the kit from hid extra. I have an extra ballast if you need one . $100 shipped. Mike
I have the same exact problem. My driver's side (left) headlight is out - the fuse pops everytime I turn on the headlights. Both bulbs are good. I switched them to opposite sides, and they both work in the good (right) headlight.
I then took off the front bumper, and plugged the left housing unit into the right lighting harnesses (and vice verse). This basically rolls the ballasts to opposite side.
Result: the passenger's side (right) headlight is out - the fuse pops when I turn the headlights on.
This means I have a bad ballast.
The Dealership wants $475 + tax for a new ballast... Ridiculous... Even the "oem acura parts" website wants $350 for a single ballast... Not worth it (IMO)...
So I ordered an HID kit off ebay for $60 (has both left and right HIDs). It should hopefully come in before the weekend. If so, I plan to put it in on Saturday.
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
