Oil filter question
Old Nov 2, 2003 | 07:52 AM
Bobbydoedoe's Avatar
I'm Cool
Oil filter question
For those of you who change your oil at 7500miles and filter around 3k miles. Do you guys just replace the oil filter? and won't the oil start dripping if you didn't completely drain the oil? thx in advance
Old Nov 4, 2003 | 12:03 PM
rmstoico's Avatar
i like chicken
drain your oil first, then change your filter, then fill oil. change between 3-6k miles. no need to change every 3 if you drive alot of highway miles. oil companies are making a killing off the BIG MISCONCEPTION that oil needs to be changed every 3k miles, especially in foreign motors
Old Nov 4, 2003 | 12:09 PM
mushutofu's Avatar
Best way to gauge is just regularly check your dip stick and look for any discoloring in the oil and for any metal flakes...
When the oil looks dirty or dark in color(compared to the oils original color) then you know its time to change your oil.
I would change the filter every time you change your oil.
Old Nov 4, 2003 | 12:19 PM
SilviaGTO's Avatar
i change my filter when i change my oil
i would think if you tried to take the filter off without draining the oil, youre gonna have a mess.
Old Nov 4, 2003 | 01:46 PM
ChucksTL_RENAMED's Avatar
At 3K miles before removing the filter place a drain pan under it, or a big rag first, then unscrew it. It holds about half a quart and another one forth of a quart will drain out from where it was held onto the engine. Fill up the new filter with oil (helps prevent a momentary dry start), lube the gasket and install. Run the engine for a minute and shut off and wait five minutes for the oil to drain down to the pan. Check your dipstick and add any that's needed-should be just alittle bit.
Old Nov 4, 2003 | 06:21 PM
Bulldog01's Avatar
Masshole
Every 10k with Mobil 1 (oil and filter). I might start changing every 7,500, but the oil was pretty clean after 10 the last time. Probably overkill to do it every 7,500.
Old Nov 5, 2003 | 05:27 AM
SilviaGTO's Avatar
really? i used mobil 1 synthetic in my civic and i always changed it at 5k
Old Nov 5, 2003 | 05:36 AM
CO-CL-S's Avatar
Did it need to be changed? That's a lot of money..
Old Nov 5, 2003 | 05:41 AM
SilviaGTO's Avatar
yeah actually it did.. i ran my civic pretty hard.
bungln
Feb 20, 2019 08:47 PM
VolkingTL
Sep 16, 2015 09:10 PM
ghuns
Sep 16, 2015 04:26 PM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
