OEM CD Player! HELP!
Old Jul 30, 2004 | 08:27 PM
DURAN007's Avatar
My cd player won't load or play. Error code one shows up. This happened like a week ago but i kept playing the the cd selector 1-6 to get it to work. Seems when i load anything into slot 1 and jump to slot 6 it gets hung up after hearing the motorized noise. Now its been srewed up for 2 days now. Any ideas what is causing this to occur? There has to been a resoultion other than replacing the radio/cd. Plus how would a after market cd/player look. I noticed we have a double din size radio.
Old Jul 30, 2004 | 08:40 PM
BC2G's Avatar
Registered Big Dog
waranty... take it to the dealership let them fix it under warranty
Old Jul 30, 2004 | 08:55 PM
DURAN007's Avatar
I do not have coverage anymore. I have 73,000 miles on it.
Old Jul 30, 2004 | 09:04 PM
patsmere's Avatar
Any Lady Want One??? :-P
they have kits to fit the dash for the empty space around the head unit
Old Jul 31, 2004 | 11:50 AM
blader's Avatar
Audi S4 driver
depending on how nice your dealership is they MAY replace it for you as a goodwill type of thing .. dunno though.
Old Jul 31, 2004 | 01:19 PM
Jonesi's Avatar
Very common problem... You have to find a trick that works.. For me it was having the car off and turning it to the Acc postition and holding down the Eject button.. That seemed to reset it..
Others said smacking the side of the radio, some said they use a screw driver.. I don't recommend either of those..
Best of luck..
Old Aug 2, 2004 | 11:54 PM
DURAN007's Avatar
So what is the sequence of reseting it. Do I turn the car to acc then press power then eject? Please advise.
Old Aug 3, 2004 | 04:25 PM
Sly Raskal's Avatar
mine did this once, all i did was turn the car on and off and it worked fine. that must have reset something in the radio because turning the radio on and off didn't do anything.
Old Aug 3, 2004 | 04:39 PM
carquest's Avatar
bummer. hope mine never does it.
the only thing i can think to try is removing power from the unit entirely. disconnect the battery. for like 1/2 hour or so. the down side is that you have to re-enter your radio security code and re-set all your radio stations. the intent is to get the unit to re-boot entirely. may work, may not. but its cheaper than a new unit.
lastly, use only CD-R or CD-R/W (don't think this unit will play CD-R/Ws but if it does.....). this way if the CDs stay stuck you haven't lost the master copy. you'll be even more bummed if you have to replace the unit and lose 6 master CDs to boot.
good luck.
Old Aug 3, 2004 | 05:55 PM
ATownTXTypeS's Avatar
I'ld hate to see the price on one of those factory radios......try eBAY
Old Aug 4, 2004 | 08:46 AM
DURAN007's Avatar
I turned on the radio pressed an cd slot 1-6 any one then press eject, then turn off the radio before the error code displays. Then the next morning i put the car in acc mode and the cd ejected and the player was working fine. Go figure? This worked for me. I t won't work if I do it after the error code displays. I have to atleast wait like 2hours. Hope this helps other cuz it helped me.
Old Aug 5, 2004 | 10:30 PM
sxsublime's Avatar
cl-:P
[IMG][/IMG]
this is it with a new head unit. All you need is the metra kit to go around it. (sorry about the picture quality)
Jul 16, 2017 07:33 AM
Fool
Mar 10, 2016 08:42 PM
Mr.Tea
Oct 2, 2015 10:32 PM
ROWDY621
Sep 30, 2015 03:20 PM
