Is this normal ? calling techs especially
Beware of leakage
I call my dealer yesterday to schedule appointment to have some parts that were ordered, put on. I also inquire about having the tranny flush and fill and how much will cost ect. I am put on hold while she checks it out, then I get the response " We don't have the machine that flushes the fluid out WTF?!?
They said they could do the, add fluid run through all the gears, empty and replace for $175 OR they could change the fluid for $75.
So I am trying to take care of the tranny, but they don't have the machinery to do the flush and fill ? I don't get it.
IMO, too expensive and here's what's going to happen. You be the judge.
That sounds pretty expensive
; the Acura folks don't have the machines that will do the job easily without messing-up the tranny. The machine needs to "patch into" the tranny cooler lines (this would be perfect and easy if you had an add-on tranny cooler *and/or* someone smart enough to "patch in" to the existing ATF cooler/warmer).
The flush requires the tech to remove ATF, then add new ATF, then run through a sequence of putting the car through the gears. This process is repeated a three times until the ATF is "almost" brand new (you never get rid of all of the old stuff).
The change is only one cycle -- you just remove some ATF, and add some.
Here is a link from the Archives on what is done:
ARCHIVES > Extremely Useful Topics > What's the steps to change tranny oil??
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
Beware of leakage
Re: IMO, too expensive and here's what's going to happen. You be the judge.
Guess it may be better to have nothing done then
Inspire08
10-30-2015 04:00 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
IndycarFaster
09-11-2015 02:52 PM
