Noob question about the tb spacers, gaskets
I gotta ask, but about those TB Spacers and IM gaskets (on Excelerate) I heard that those give you a slight boost in HP, but is that only noticeable when the car is really getting heated? Like, does it protect against heatsoak moreso than improve HP or anything?
So I guess what I'm trying to ask is will I really only notice a change in performance if I've been cruising around with the engine at normal operating temp, or is it kind of all across the board? I know you're supposed to get 4-5 HP increase, but is it only noticeable when the engine is fully warmed up?
lowrd on tein CS biatch
you will not "notice" the power gains from the tb spacer. I have it, it's more for looks and piece of mind (that u got lot of mods). Does it help heat soak, definitely (how much i dunno).
I would do the P2R thermoblock manifold gasket when/if you do the tb spacer.
wham bam thank you ma'am
u got to stop talking about ur previous car. it was a pos. end of story
i have had the coolant bypass on my tl for 3 years now and no problem, i have it bypassed on my cl for almost a year and all is good. members here have had it bypassed for longer and no problems all it does is heats up the tb which will heat up the incoming air so the engine can warm up faster in cold climates. THATS all nothing to do with IDLE
13.2@106mph G37 RWD Sedan
Whats up with RDX owners?
Mine is bypassed. Im trying to get rid of all heat soak. Ive not had any issues.
I got the Shifts
useless mod. look at the physics. heat rises as it radiates from the engine block. it gets trapped in the pockets of the hood and warms up the intake manifold. most of the heat comes from the headers and not from the block to the manifold. nobody has proven the gains and 4-5hp can be created by having multiple dynos back to back.
^^^ that's my philosophy.
for how hot it get in comparison to everything else, i'd rather just let the car function the way it was intended to.
My CAI and manifold are so damn cool anyways I don't think a lil heat in a 2inch tb would soak the air enough to make a diff.
in the US on hot hot days... then i could see it making some difference, but for the times it'd do good, it'd just cause my car to idle high for longer most of the time.
Maybe it was a placebo effect, but I noticed a difference after I bypassed the coolant lines in the TB. Then again, my car is super inconsistent so maybe it was just running good that day.
