New rotors
If He Dies...He Dies
New rotors
I heard that you have to wash the rotors with soap and water before installing them to get some type of non-corrosive type chemicals off it. Is this true? Has anyone heard of this?
I've been thinking about doing a DIY on my front rotors since I've seen this link
TL rotor replacement DIY
Honkey
I've always just whiped them down with brake cleaner first to make sure the pads aren't grinding in any dirt. I could be wrong, but it's always worked well for me.
oh ok. I was looking at "2 Guys' Garage" car show on the SPEED channel or some show on there, and they said something about washing off your new rotors because the new rotors will have some chemical on it that needs to be removed before being installed.
yea, i spray down most of the hub and rotor that touches the hub with brake cleaner. the stuff is pretty strong and dries quick. be careful not to spray any rubber or your paint. i would also put a box under whatever you are spraying because if you spray the wheel hub/brake assembly a lot of junk will spray right off on to the ground.
7-30-05 First Place STS!
don't use soap and water...only thing you ever clean your brakes with is brake cleaner...also yes it's a good idea to wipe them with brake cleaner before installing the rotors..don't forget to brake them as well =)
Do mechanics do clean the rotors before mount them? I don't think this mechanic that put my brembo blanks on cleaned them because I basically told him that I got better labor rate from somewhere else so he dropped his rate down to the competitor. but, I can't prove it. All I know is that when I got the car back, the rotors felt no different.
1 Post
This is from Pat Goss of the international TV SHOW MOTOR WEEK thats seen on PBS stations & the speed channel. I took a few classes with Pat being the instructor last year.
I remember him saying somehting about this & he knows alot about cars & stuff.
Here is the link.
www.patgosscarworld.com/brakes.htm
Audi S4 driver
I installed my Rotora's and axxis pads .. occassionally they squeal like HELL. I didnt clean them before I put them on. What can I do about it now besides taking it all back apart?
Audi S4 driver
All of the above, but on random occassions. I guess more at low speeds though. Braking is MUCH improved without a doubt, the car actually starts slowing down now when you use the brake pedal. No fade whatsoever .. they will feel funky while breaking in, mine still are.
DP's for life
Just wondering...
Originally Posted by Bluto
My Rotora came with instructions to wash with soap and water & Do Not Use Brake Cleaner.
![Racing](https://acurazine.com/forums/images/smilies/racing.gif)
I was going to chime in, too, about the Rotora instructions saying to use soap and water.
I'm having mine installed on Monday (slotted Rotoras + ultimates). I'll probably wash them at home before I drop off the car.
By the way, will the shop need anything else to do the install? They were fine with me supplying the parts--didn't think to ask if they will need anything other than the rotors and the pads. Will the axxis pads fit into the existing setup?
Originally Posted by sundance_gold
Kewl! Thanks!
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
