New rotors
Old Jul 23, 2004 | 01:44 PM
MisterMehoff's Avatar
If He Dies...He Dies
New rotors
I heard that you have to wash the rotors with soap and water before installing them to get some type of non-corrosive type chemicals off it. Is this true? Has anyone heard of this?
I've been thinking about doing a DIY on my front rotors since I've seen this link
TL rotor replacement DIY
Old Jul 23, 2004 | 01:46 PM
4pumpedCL's Avatar
Honkey
I've always just whiped them down with brake cleaner first to make sure the pads aren't grinding in any dirt. I could be wrong, but it's always worked well for me.
Old Jul 23, 2004 | 01:48 PM
NiteQwill's Avatar
Adventurist.
I don't see how it could hurt if you do. Sounds like a good idea, but I've never done it in the past, you pads sweep all the crap off anyway.
Old Jul 23, 2004 | 01:50 PM
CleanCL's Avatar
Well brand new rotors should be clean (mine came in sealed bags inside the box), then I just spray the surface of the rotors with Anti-Squeel spray and put them on, pads do the rest.
Old Jul 23, 2004 | 02:03 PM
oh ok. I was looking at "2 Guys' Garage" car show on the SPEED channel or some show on there, and they said something about washing off your new rotors because the new rotors will have some chemical on it that needs to be removed before being installed.
Old Jul 23, 2004 | 03:04 PM
fuzzy02CLS's Avatar
Use brake cleaner, or some sort of automotive degreaser. NOT soap & water.
Old Jul 23, 2004 | 03:27 PM
CleanCL's Avatar
yea, i spray down most of the hub and rotor that touches the hub with brake cleaner. the stuff is pretty strong and dries quick. be careful not to spray any rubber or your paint. i would also put a box under whatever you are spraying because if you spray the wheel hub/brake assembly a lot of junk will spray right off on to the ground.
Old Jul 23, 2004 | 07:36 PM
azian21485's Avatar
7-30-05 First Place STS!
don't use soap and water...only thing you ever clean your brakes with is brake cleaner...also yes it's a good idea to wipe them with brake cleaner before installing the rotors..don't forget to brake them as well =)
Old Jul 24, 2004 | 09:10 AM
Do mechanics do clean the rotors before mount them? I don't think this mechanic that put my brembo blanks on cleaned them because I basically told him that I got better labor rate from somewhere else so he dropped his rate down to the competitor. but, I can't prove it. All I know is that when I got the car back, the rotors felt no different.
Old Jul 26, 2004 | 01:07 PM
FTM-1's Avatar
Here is a link that might explain what your talking about.
This is from Pat Goss of the international TV SHOW MOTOR WEEK thats seen on PBS stations & the speed channel. I took a few classes with Pat being the instructor last year.
I remember him saying somehting about this & he knows alot about cars & stuff.
Here is the link.
www.patgosscarworld.com/brakes.htm
Old Jul 26, 2004 | 01:33 PM
Bluto's Avatar
Find beauty in dissonance
My Rotora came with instructions to wash with soap and water & Do Not Use Brake Cleaner.
Old Jul 26, 2004 | 02:49 PM
mrsteve's Avatar
^^ Interesting, i'd follow the Rotora suggestion, and I WILL follow their suggestion when I install my rotors; they were delivered today
Old Jul 26, 2004 | 03:41 PM
blader's Avatar
Audi S4 driver
I installed my Rotora's and axxis pads .. occassionally they squeal like HELL. I didnt clean them before I put them on. What can I do about it now besides taking it all back apart?
Old Jul 26, 2004 | 03:43 PM
mrsteve's Avatar
^ At low speeds? When stopping from highway speeds? When coming to a stop? When do you experience squeal? I don't have an answer for you, just for my personal knowledge
Old Jul 26, 2004 | 03:48 PM
blader's Avatar
Audi S4 driver
All of the above, but on random occassions. I guess more at low speeds though. Braking is MUCH improved without a doubt, the car actually starts slowing down now when you use the brake pedal. No fade whatsoever .. they will feel funky while breaking in, mine still are.
Old Jul 26, 2004 | 03:51 PM
mrsteve's Avatar
Mine just got delivered today, although it is going to be a month or so before I install them. Waiting for my powder coated calipers
Old Jul 26, 2004 | 03:59 PM
Artwork's Avatar
DP's for life
What axxis pad do you have? The ultimates or the metal masters?
Just wondering...
Old Jul 26, 2004 | 04:16 PM
blader's Avatar
Audi S4 driver
Ultimates.
Old Jul 26, 2004 | 09:43 PM
fender4's Avatar
Ditto here;; also my acura mech does the same,, soap and water only,,,
Old Jul 27, 2004 | 12:05 AM
CleanCL's Avatar
well to rid the squeel you can head to pepboys or autozone and pick up a spray usually called "Anti-Squeel" lol i used that when i did my brake and rotor change and i got little to no squeeking upon first 200 miles, then it basically is silent after 500 miles
Old Jul 27, 2004 | 02:01 PM
sundance_gold's Avatar
I was going to chime in, too, about the Rotora instructions saying to use soap and water.
I'm having mine installed on Monday (slotted Rotoras + ultimates). I'll probably wash them at home before I drop off the car.
By the way, will the shop need anything else to do the install? They were fine with me supplying the parts--didn't think to ask if they will need anything other than the rotors and the pads. Will the axxis pads fit into the existing setup?
Old Jul 27, 2004 | 02:09 PM
blader's Avatar
Audi S4 driver
Yes, everything fits on just like stock.
Old Jul 27, 2004 | 03:12 PM
Kewl! Thanks!
Old Jul 27, 2004 | 03:23 PM
JakeCL's Avatar
i didnt wash mine, uh oh
Old Jul 27, 2004 | 04:46 PM
fender4's Avatar
Originally Posted by sundance_gold
Kewl! Thanks!
Don't forget to retrain your braking foot,,, after you drive with these brakes you'll know what I'm talking about.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
