New Motor is IN!!!
Originally Posted by swift22
if you are still getting pinging around 11A/f my thoughts are that one of your injectors may be failing your fuel VOLUME is not enough because of a clogged filter or failing pump.
That is crap about the dyno sheet, let's see some numbers! Otherwise we will have to assume the numbers are still the same as the previous setup, 221whp!
Originally Posted by NightRider
I think theres only a certain amount of compensating you can do as far as tuning A/F goes until you will need to upgrade injectors, especially with HBP. There are shops that will make HBP's in the 7-10 range too FWIW.
Alright homie
Jamus22
Jun 11, 2023 10:08 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
Sep 25, 2015 06:14 PM
