New Manifold with Intercooler
Old 11-14-2003, 04:12 PM
  #161
scalbert's Avatar
Originally posted by mattg
that is awesome steve. can't wait to see the finished product.
we still on for the intake swap?
Thanks Matt... Yep, my upper manifold will be sent your way once the new unit is in place and tested.
Old 11-14-2003, 04:19 PM
  #162
mattg's Avatar
you're the man.
Old 11-14-2003, 04:34 PM
  #163
ModAddict's Avatar
Originally posted by scalbert
Correct, the light gray one with the ten bolts (eight bolts and two studs on your car ). Also, the upper portions of it; the highest elevation sections but still at the corners.
It will be done yet tonight!
Old 11-14-2003, 05:07 PM
  #164
ModAddict's Avatar
The :-* went to the store, so I asked her to get me some clay,....if you could have seen the look,....like WTF
Old 11-14-2003, 05:47 PM
  #165
ModAddict's Avatar
1" at both the front corners, 1.25" at the back left, and 1.5" at the back right.
How does that compare?
Old 11-14-2003, 05:55 PM
  #166
allmotor_2000's Avatar
I really wonder how unmanageable this car will be with 380+ WHP, maybe 400+ WHP...
I was driving into work this morning at about 6:00 AM and the temps were about 35F; the coldest I have been in with the blower. I rolled on the throttle in 2nd and it broke loose easily; this was at 45 MPH already and without any clutch input. I have 235/45 ES100 tires and had been on the interstate so they were warmed up. Another 60 - 80 WHP is bound to create traction limitations well into 3rd. :o
Hehe...
Old 11-14-2003, 06:07 PM
  #167
scalbert's Avatar
I can certainly understand...
Old 11-14-2003, 06:17 PM
  #168
scalbert's Avatar
That is about 0.25 more than I have and about what I expected. When I made my RES plate and had it on my '01 CL-S I had plenty of room. After I traded for the '03 6-Speed and I put the plate on I found I had less clearance (and even put a ding in the bottom of the hood).
I suspect the manual sits a little higher maybe as a result of or the reason for the additional engine mounts.
I’m going to do one more test measurement this weekend to be sure. But it looks good for all included vehicles.
One more thing; can you measure from the centerline of the upper manifold cover to the factory installed strut tower brace; in a level fashion?? This may be slightly different for the two vehicles and I want to be sure here as well.
Old 11-14-2003, 06:19 PM
  #169
scalbert's Avatar
Originally posted by allmotor_2000
Hehe...
You already know...
Old 11-14-2003, 06:30 PM
  #170
ModAddict's Avatar
9.25" from the center of the manifold cover to the front of the factory strut brace.
Old 11-14-2003, 06:34 PM
  #171
scalbert's Avatar
That is exactly what the CL is and is good. I know the TL has a longer wheel base but I expected this dimension to be the same.
Old 11-14-2003, 06:36 PM
  #172
Community Architect
robb m.
astro's Avatar
amazing progress Steve, keep it up
Old 11-19-2003, 05:31 AM
  #173
scalbert's Avatar
I got the intercooler on order but one catch, the price has gone up to $722.
Old 11-19-2003, 05:38 AM
  #174
ModAddict's Avatar
Do you want to order 5 or 6, to get the $$$ down? We can send you the money. I'm not sure how much it went up, so I'm not sure if that will make a diffference or not. Just a thought.
Old 11-19-2003, 05:42 AM
  #175
scalbert's Avatar
Since these are customs I'd rather not order extras until the system is confirmed and tested. They went up $72 so not too bad.
I'll work on discounting when ready to produce multiple units.
Old 11-19-2003, 05:48 AM
  #176
ModAddict's Avatar
I knew that was your direction, and it is good one, just make sure somehow down the line, our discounting includes yours, and then some!
Old 11-19-2003, 08:02 AM
  #177
Caddy©'s Avatar
Forgive my "DUMB" question, but will the Intercooler ONLY work in conjunction with the SC ?
Old 11-19-2003, 08:09 AM
  #178
scalbert's Avatar
There is no need for it without forced induction. The reason for an intercooler is due to the fact that gases (air in this case) heat when compressed. The intercooler is there to remove the added heat.
Old 11-19-2003, 08:14 AM
  #179
Caddy©'s Avatar
Excellent !
Thanks Steve
I'd like to consider this when available
There is no need for it with forced induction. The reason for an intercooler is due to the fact that gases (air in this case) heat when compressed. The intercooler is there to remove the added heat.
Old 11-19-2003, 11:12 AM
  #180
ModAddict's Avatar
Did they say how long it would take to ship it?
Old 11-19-2003, 11:49 AM
  #181
scalbert's Avatar
One week.
Old 11-19-2003, 11:52 AM
  #182
Chemmech's Avatar
Is the new price for the intercooler with or without the other system stuff (like a water pump, reservoire etc.)?
Old 11-19-2003, 01:27 PM
  #183
scalbert's Avatar
That is just the intercooler core. The rest of the stuff should just about double this price.
Old 12-03-2003, 09:30 AM
  #184
ModAddict's Avatar
The IC core should be there soon.
Old 12-03-2003, 10:10 AM
  #185
scalbert's Avatar
Hopefully; if they didn't get in through production the week I ordered it wouldn't get done until this week. But regardless, it should be soon so start warming up your wrenches and sockets for a test fit on the TL-S.
Old 12-03-2003, 11:47 AM
  #186
ModAddict's Avatar
....... so start warming up your wrenches and sockets for a test fit on the TL-S.
I almost bought a propane heater T-giving weekend, but the store I went to did not have one, and as I said, it was only 40*, so it wasn't that bad yet. However,... there will be heat in the garage soon, as I do plan on working on the TL-S over the winter because of all the things you have brought to fruition. My plans over the winter include an Intercooler kit, a new gauge pod, rewiring the gauges and wideband, E-Manning the ECU, a new cat back (?), and who knows,...maybe some sort of traction bar up front.
Old 12-10-2003, 04:27 AM
  #187
scalbert's Avatar
Guess what arrived yesterday...
I don't have a camera right now and I will be taking it by the machine shop later so no pictures until it is ready. But that shouldn't take more than a few days.
It is slightly different than what was shown in the simple images available. I had asked from mechanical drawings but was told they are not available. Due to these differences it will require some slight alterations which will be transposed to the drawings when complete.
I'll post the pictures when ready.
Old 12-10-2003, 01:11 PM
  #188
ModAddict's Avatar
Slightly different where it mates up to the new plenum?
Old 12-10-2003, 03:34 PM
  #189
TranceFusion's Avatar
good shit..
Old 12-11-2003, 02:43 AM
  #190
scalbert's Avatar
Yep, the simple pictures appeared to have had a slight lip to the ends but that is far from being the case. The end cap for the water flow on one side is nearly in line with the IC core face.
What will be required is to cut off the two back plates and cut them shorter. The IC will then sit flush and can be welded up.
Old 12-11-2003, 06:33 AM
  #191
maxima troll :)
blubyu2k2's Avatar
can't wait to see this
Old 12-11-2003, 12:23 PM
  #192
ModAddict's Avatar
Is it done yet? j/k
I can't wait either, this thing is going to be cool!
Old 12-11-2003, 06:25 PM
  #193
Bleed Honda Blue
sgmotoring's Avatar
I thought I was crazy to do a 3.5 swap and supercharged. But you are the man. By the way I blew my engine boosting at 6psi. I knew that engine didn't like the pinging. I will try to post some pictures of my swap in progress.
Old 12-11-2003, 07:49 PM
  #194
Smitty's Avatar
WHAT!!!!!!!!!.. some of us are seeing 7lbs of boost with the IMRC disconnected...
Old 12-12-2003, 03:28 AM
  #195
scalbert's Avatar
Huh, what blew in it??
Several of us have been running more boost for longer and have healthy motors. There must be something going on with that fuel supply.
Old 12-12-2003, 04:59 AM
  #196
ModAddict's Avatar
Old 12-12-2003, 05:00 AM
  #197
ModAddict's Avatar
This was from the bad dyno post;
Sounds like you are trying to get started right away with the 3.5 swap! You know,..... running the high boost pulley, with 91 ontane, on the dyno, pinging away, waiting to melt a piston or two.
Old 12-14-2003, 12:32 PM
  #198
Bleed Honda Blue
sgmotoring's Avatar
I removed the head last night and I got a blown #2 cylinder piston rings. The piston was damaged but I think that was due to me driving it more then 50 miles after the rings were blown. I have a auto trans CL-S and yes I was only boosting 6psi, hell maybe 5.5psi. I have a dyno chart with a/f and it show that I was running rich, so that was not detonation due to lack of fuel.
Old 12-15-2003, 03:32 AM
  #199
scalbert's Avatar
Maybe the ring was bad all along and became visible (audible in this case) when boost was applied.
Please keep us informed of the status.
Old 12-15-2003, 04:06 AM
  #200
Smitty's Avatar
How many miles did your car have on it, when you installed the S/C'er?
And I did notice your out in CA, the highest OCTANE available to you is 91 octane?....... that would worry me.
Smitty
Quick Reply: New Manifold with Intercooler
