Need some help with lug nut stuck
Old Dec 7, 2008 | 02:41 PM
DFoster0's Avatar
Angry Need some help with lug nut stuck
Alright so im changing out my rotors for some cross drilled ones I finish with 3 of them then i get to the last wheel, then the last lug of the 5 and this one just turns and bends down. Oh yeah I have tuner lugs which need a special socket which cracks in half during all this so now is where I ask? how do I get this lug off, I'm assuming the stud holding it on is done since it's bent, I've tried hitting it off but this isn't working. Also Ive been looking into buying a new stud when I eventually get it off and no one has it autozone, pep boys. Anyways any guidance chime in, I'm pretty pissed right now cause the place I got new tires recently from overtightened my lugs and surly cross threaded this one.
Thanks in advance Dan
Old Dec 7, 2008 | 02:51 PM
disgruntlednut's Avatar
01 Type-S, Sexy Silver
Man I had a place strip 3 studs so lemme tell you, I wasn't a happy person... Well, the studs are pretty cheap, even from the dealer they shouldn't be more than like 3 bucks, but replacing them isn't an easy task. The hub is pressed on so you'll probably have to take it to a machine shop to have them pull it apart. Once you've got everything apart just hammer it out and pull the new one through from behind.
Old Dec 7, 2008 | 03:26 PM
CleanCL's Avatar
air chisel
king gator grip socket
Old Dec 7, 2008 | 03:58 PM
GrandeInter10's Avatar
Si Vis Pacem, Para Bellum
Unnecessary. It's doable.
Old Dec 7, 2008 | 04:13 PM
DFoster0's Avatar
thanks for the input
Old Dec 7, 2008 | 06:55 PM
Woofer's Avatar
Restored this in 1998
If it were me I would go ahead and replace the other 4 lugs while its apart.
Old Dec 8, 2008 | 10:44 AM
DFoster0's Avatar
Ok found a replacement socket at a tire place so at least I can drive now it was tough to find went to like 4 places, gonna break the bent stud off after work this week
Old Dec 11, 2008 | 07:18 PM
02CL-TypeS's Avatar
new studs aren't hard to put in. The hardest part is getting the old stud out....just hamer hammer hammer. You can install a new stud with a simple wrench. Just buy a lug nut without a cap so it screws all the way down and pulls the stud securely into the hub
Old Dec 11, 2008 | 07:42 PM
invisiblewar's Avatar
an asshole from florida
i cracked a few cheap lugs on my studs once and me and my pops had to dremel the fucking studs out. It took about 2 hours to do each one and i thought my hand had turned into metal. those tuner lugs are shit I will never ever ever buy those things again. (the ones that have the hole straight through the middle)
neuronbob
23
Jul 16, 2019 10:48 AM
Jul 16, 2017 07:33 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
