New Shifter Bushings?
Old Dec 10, 2008 | 02:02 PM
alxmlr789's Avatar
*6MT*
I have searched and read around here a little bit but couldnt figure out exactly how much they benefit the CL 6MT, or where to buy them. Where would I look, and what do i buy?
I've read that on 04-08 TL MT's they make the shifting feel better and a little smoother. I'll take a guess that it is still the same on the CL's.
Anyways, if you guys have any information or opinions i would love to know.
Thanks guys.
Old Dec 10, 2008 | 02:30 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
there's no reason not to do it. it's smoother, easier into all gears, you know when you're in or if you're not in the gear (my 2nd has 2 engagements like the tl's 3rd gear.. argh).
basically instead of being vague it's precise..
like using a butterknife instead of a scalpel to do surgury. and they're only $30. but personally i would do the clutch bypass too.. that's free (or if you want to upgrade the line it's $30 for an SS line)
Old Dec 10, 2008 | 02:35 PM
alxmlr789's Avatar
*6MT*
Man, I've got alot to learn.
Where can i get these bushings, and how do i do this clutch bypass?
Old Dec 10, 2008 | 02:53 PM
Allout's Avatar
Blown is Best
Corsport makes the bushings:
http://www.heeltoeauto.com/Corsport-...-pr-56012.html
Old Dec 10, 2008 | 03:02 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
Originally Posted by Allout
i bought mine direct from corsport but it looks like they've increased their price to $35.
search on this forum 'clutch bypass' or 'clutch damper' or cdd.. it's a small device, roughly the size of a puck. really easy actually, make sure you have flare nut wrenches tho (or you'll strip ends like i did). there's 1 line going into the device and 1 line going out. you can take the long rubber clutch line and just reroute it to where the other line goes, and you're done. basically, if you've ever tried doing fast shifts and you feel like the clutch is slipping or it grabs very very slowly, that's the CDD working it's magic.. burning away your clutch
Old Dec 10, 2008 | 05:08 PM
fuzzy02CLS's Avatar
Those are the bushings I got. 04+ TL fitment will work on CLS as well. I may install them sat since all this talk came up recently. I kinda forgot I had them all this time.
Old Dec 10, 2008 | 07:40 PM
Allout's Avatar
Blown is Best
Don't forget to lube them up.
Old Dec 10, 2008 | 07:49 PM
Allout's Avatar
Blown is Best
Here's the thread on the CCD Bypass. I added the steel braided line and I like the feel.
https://acurazine.com/forums/showthr...312&highlight=
Old Dec 10, 2008 | 09:30 PM
fuzzy02CLS's Avatar
You have to lube them? The instructions don't say that?
All purpose grease ok to use?
Old Dec 10, 2008 | 09:41 PM
Accord_V6_400m's Avatar
4drs just wanna have fun!
So far I have teh CDD removed, SS clutch line and shifter bushings, next up is a better clutch kit that can handle the increase in power and faster shifts.
I greased mine up with some lithium grease.
Old Dec 11, 2008 | 12:04 PM
jproy's Avatar
MP90 uninstalled
They are great. I have had mine for three years. make sure to grease them up. Lithium works well.
Old Dec 11, 2008 | 12:05 PM
jproy's Avatar
MP90 uninstalled
The CCD bypass is nice too. Had it off for three years..
Old Dec 11, 2008 | 08:27 PM
alxmlr789's Avatar
*6MT*
Is the CCD bypass reversible? In case I do not like the feel?
Can any negative effects be caused by me doing this mod?
Old Dec 11, 2008 | 08:42 PM
jproy's Avatar
MP90 uninstalled
You wont feel anything different. The clutch will just engage as fast as you take your foot off the clutch. With the CCD, fluid flow back to the clutch master cylinder from the clutch slave cylinder is restricted to a max flow rate so the clutch can only engage at a maximum rate of engagement. That rate of flow is supposed to be slow enough to help with a smoother engagement of the clutch if you are a very shitty stick driver but it doesnt do much except force you to slip the clutch some when you let off the clutch by dumping it, whereas without the CCD, the clutch would just "hook up" instantly at the same rate as the clutch peddal came off the floor, however fast you make that happen.
Its completely reversable. Just reinstall it. No modification or additional parts necessary.
Old Dec 12, 2008 | 07:24 AM
fuzzy02CLS's Avatar
It does feel a little different. There's more vibration in the clutch pedal. You can feel that. You will get used to it though.
Mod notes....
Leave the CCD in the car, just disconnect the lines.
Also you will have to bleed the clutch. This is easier from under the front bumper then to try from the top of the engine.
Jul 16, 2017 07:33 AM
spoiler900
Oct 10, 2015 06:48 PM
MikeJM310
Sep 24, 2015 07:24 PM
