need help wiring a extra tcs/cruise switch
I just installed led lights in the upper+lower grills.And will be installing angel eyes this week.I will be using a tcs/cruise switch.I want to wire eyes + led's to each switch .switch will be mounted in thre dummy spot where the vsa switch would go. Also should I get power from the other tcs/cruise switch.and do I need to up fuse sizes ?
To many cars in my garage
I would not get power from the other TCS switch because if something goes wrong them you may blow the actual TCS.
I got power from the ciagrette lighter that way when the car is off the lights are off.
Also I wired my angel eyes to the parking lights so as soon as I turn my lights on there on.
Oh if your doing it by the book and you wana be safe everything needs a fuse.
I could Guess at which wires are for what but I think that you should get a wire tester and take the stock one out and test each wire
put one side on ground and take the wire tester and poke throught the plastic when the switch is off and and the lights are on if it doesnt light up its either ground or power
this is just an example but thats how I would do it
but if I had to guess
Black= ground
Light blue= power out for cruise or TCS
Green yellow= power out for cruise or TCS
Reds=power in for lights
Orange=power In for cruise or TCS
Just a guess
Black= ground
Just a guess
Speaking of pics hurry up and do the install of the angel eyes and post some pics I wana see how they look Im goin update my cardomain page soon got my 2 12s and 2 10s installed (custom boxes and trunk)
I wanted 2 seperate switches and this was the switch that was available ,and I also got a clock,new console woods and 2 whole door pannels to get the woods for $50.wanted to go back to wood insted of color matched woods. I always change stuff again and again
Stop Lying that car has been washed it looks perfect by the way
It makes me mad when some says there car is filthy when it has just been cleaned you wana see a dirty Black C LS You should see mine
Whats up with RDX owners?
Seriously, I washed my car last saturday. You should see the front end. I put over 300 miles on it since saturday and I've got the bugs to prove it.
So, uh, thankyou.
Enough with the threadjacking.
LETS GET THIS MAN SOME ANSWERS!
SUPRMN84
10-07-2015 09:46 PM
xsilverhawkx
09-28-2015 06:51 PM
