Need help with wheel hop problem
Old 02-17-2015, 08:09 PM
03CLSBullet's Avatar
Hey guys, new to this foroum, just my little story i have an 03 cls 6 speed with intake, XS headers and comptech pipes, i have raced the car from a 40 roll and its always ran really hard, last week i took it to the track nearby for the 1st time and it was horrible. The car would hop all the way through 1st gear and i was only launching at 2k rpms, it ran a 10.00 in the 1/8 with like a 2.65 60ft. It shakes the tires rally bad where i just cant even step on it, what could this be ?
Motor mount problem, suspension, tie rods, axles ?
Im hoping to get some help before i spend a bunch of money thanks
Old 02-17-2015, 08:34 PM
3.5 psi
gnuts's Avatar
It's a combination of things but a lot of it is suspension. Is yous stock? Motor mounts, get wider stickier tires, radius rod bushings.
justnspace (02-18-2015)
Old 02-17-2015, 09:53 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Motor mounts a big one, especially if old or broken which happens frequently. Suspension is another. After upgrading suspension (shocks/springs/sways) i have zero hop 98% of the time.
The following 2 users liked this post by fsttyms1:
03 tls nc (09-18-2015), justnspace (02-18-2015)
Old 02-18-2015, 06:49 AM
thanks for the response guys,
I have tokico shocks and eibach springs lowered 2" in the front, and 18 inch rim very lightweight with brand new 225/40/18 cooper tires, but its not spining the tires, i know the difference of the car just hooping and shaking the entire car, this is gettting frustrating lol
Old 02-18-2015, 06:52 AM
Received 16,261 Likes on 11,972 Posts
maybe you should learn on how to feather the throttle.
its a mid powered FWD vehicle.
you're going to get wheel hop if you punch hard through 1st.
there's no way around it
mike88se (08-23-2015)
Old 02-18-2015, 06:53 AM
p.s. wheel hop is how you break things.
DONT DO IT.
learn to feather the throttle in first, then as soon as you hook, MASH THE FUCKING GAS
teh CL (02-18-2015)
Old 02-18-2015, 07:12 AM
This isint my 1st car i know how to drive, im launching at 1500-2000 rpms at less than half throttle and the car hoops all thaaa waayy thru 1st gear
Old 02-18-2015, 07:13 AM
By them time im able to punch it im almost half way down the track, is only a 1/8 mile
Old 02-18-2015, 07:34 AM
all i know, is that if you continue to wheel hop while trying to race down the track, you're going to break things.
if it were me, i'd refrain from doing it.
it's just a characteristic of the car.
Old 02-18-2015, 07:39 AM
I had an 01 cls before and it spin the tires but wouldnt hop, i know the 6 speed hops a little more but this much cant be normal there has to be something that helps a whole lot more
Old 02-18-2015, 07:42 AM
^so, you're not gonna take any of the above advice?
both fatty and gnuts gave you great suggestions
start there, as wheel hop is WHEEL SPIN!
Old 02-18-2015, 07:44 AM
motor mounts, bushings, stiffer suspension, sticky wide tires, etc....
what kind of tires are you running right now?
I bet that is the problem.
throw on a set of strict summers
Old 02-18-2015, 07:46 AM
and i hate to say it.....
but you diagnosed your own problems....
because you have a six speed, you can control the amount of power you lay down.
FEATHER THE DAMN THROTTLE!
Old 02-18-2015, 08:59 AM
Yes iam open to anything at this point
How do i know if the motor mounts are bad ? How do i know if its suspension ? How can i tell if the bushing are bad ? I just dont wanna buy things for no reason i dont have money like that lol
And how much you want me feather the throttle launching at 1500 rpms and going a quarter throttle all the way through 1st gear ????
Old 02-18-2015, 09:04 AM
Tires are cooper zeon rs3
Old 02-18-2015, 09:09 AM
pretty good read:
mc²racing
Old 02-18-2015, 09:10 AM
3.5 psi
gnuts's Avatar
have someone rev the car while you look at the engine. A lot of movement is not good. How many miles on the car? You can see the bushings and they may look worn and cracked. Xlr8 has poly mounts.
Not sure if you mentioned, how wide are your rims?
Old 02-18-2015, 09:33 AM
123k miles and the tires width are 225 not sure on the width of the rims
wider tires!
Old 02-18-2015, 10:15 AM
My cousin has another cl And anything wider than 235 rubs when you turn
Old 02-18-2015, 10:35 AM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
cooper zeon 225s..
TacoBello (02-18-2015)
Old 02-18-2015, 10:37 AM
3.5 psi
gnuts's Avatar
I have 235/40/18 on 8" wide rims. It depends on the offset of the rims if you'll rub.
Old 02-18-2015, 10:55 AM
I will check on those mounts and the bushings when i get home from work and will go from there.
Anyone ever used or heard about the torque dampers will they help ?
Old 02-18-2015, 11:14 AM
Lone Wolf
brian6speed's Avatar
There are ways around it. you can hook up good without wheel hop, or spin tires without wheel hop.
Obviously you don't just want to mash down the gas pedal in first, and need to feather it. This is an issue for most people, especially now since everything comes with launch control. You can install an aem stand alone that has launch and traction control.
Things to help with wheel hop include:
Motor Mounts
Stiffy Mount
Torque Dampers
Radius Rod Bushings
Shocks/Springs or Coilovers
Poly/Spherical Bushings
If that is not enough try traction bars and slicks.
The reason you get wheel hop is because the car is compromised for comfort, not because it is fwd. Rwd cars can also suffer wheel hop, but not as much of an issue as fwd in commuter vehicles.
Old 02-18-2015, 11:16 AM
^you just listed everything every one already said.
Old 02-18-2015, 12:00 PM
3.5 psi
gnuts's Avatar
The ingalls stiffy mount helps. You can also search here for NRG dampers. The 6speeds have 2 dampers, front and rear. It's a pretty cheap upgrade. I can't remember off hand, but some civic model works. With poly mounts, dampers and a stiffy mount your engine shouldn't move much at all.
Old 02-18-2015, 03:25 PM
Thanks for all the help guys
If anyone else can think of anything else, or anyone thats had this problem please keep going with suggestions
Old 02-18-2015, 04:51 PM
I got home and reved the car hard while looking at the motor and the only mount that seems to move a little is the passanger side.
Also the 2 damper move a little can they be thigthend up a bit ?
Old 02-18-2015, 05:10 PM
Lone Wolf
I run 255 and don't rub. There is more to consider than the 235 number.
I listed my response without wasting my time reading other responses I won't learn anything from.
Atleast I am not the one blaming tire size or whether summer tires or not for wheel hop.
Old 02-18-2015, 06:01 PM
My cousin had 235 and they would rub when he turned tight i guess it depends on the rims, but i dont think tire width has anything to do with the hop it will grip better but not make a difference weather it hops more or less
Old 02-18-2015, 06:49 PM
3.5 psi
gnuts's Avatar
Mounts are a wear item and if they havent been replaced, they should be at your cars age/mileage. That might be a good place to start.
Old 02-19-2015, 08:15 AM
Scottyknows007's Avatar
I would think the offset would have something to do with that as well.. my stock offset was 55+ and I moved to a rim with a 33+ offset and have 225's on them and there was no issue with rubbing until I lowered the car
Old 02-19-2015, 09:57 AM
fsttyms1's Avatar
Motor Mounts
Stiffy Mount
Torque Dampers
Radius Rod Bushings
Old 02-19-2015, 10:03 AM
fsttyms1's Avatar
LIke we have said above. Check your mounts. Odds are if they have anything over 50k they are shot. They WILL cause hop. The items listed above will help eliminate it. Check and replace all your rubber bushings to help stiffen up suspension parts that can have movement. Also your shocks. Get a better set, some that are adjustable in rebound and dampening. You will be able to dial them in and help reduce it.
And YES, wheel width does have something to do with it. The narrower the tire the easier it is for the motor to keep them spinning without hop, problem is, is spinning tires doesnt make the car go fast. The wider tire will give you the traction and help keep the tire from spinning and allow it to hook up (also better tires that have better grip as well) but when they do break loose because of the higher grip level they can cause hop.
gnuts (02-19-2015)
Old 08-16-2015, 01:37 PM
I finally solved the wheel hop problem with a set of nrg torque dampers thanks to the help of a couple members
jblessing
Wash & Wax
09-17-2015 09:28 PM
brandnewcolony
09-12-2015 10:39 AM
HOWELLiNC
09-10-2015 01:39 PM
iRaw
ILX
09-05-2015 12:10 AM
tealt
09-01-2015 09:03 AM
Quick Reply: Need help with wheel hop problem
