need help quick, 48mm or 50mm offset?
Old Jan 5, 2004 | 09:34 PM
rondog's Avatar
Former Sponsor
wheel experts, help quick, what's a better combo for our car, 19x8 with a 50 offset, or a 48 offset? howabout 18x7.5, with a 50 offset or a 48?
thanks
Old Jan 5, 2004 | 09:44 PM
JaySyn77's Avatar
You should be fine with either one. I'm rolling on 19x7.5 with a 45mm offset & Eibach Springs. I rub on steep drops with my system, but without the system I dont experience any rubbing. The only problem with 19s is that you feel everything on the road. When I had 18s the ride was a bit smoother. 48mm or 50 should work fine though...I dont think there's a "best combo"
Old Jan 5, 2004 | 09:46 PM
NSXNEXT's Avatar
19x8 +50 is perfect.
Old Jan 5, 2004 | 09:47 PM
rondog's Avatar
Former Sponsor
you don't think the inner wheel will touch the suspension on a 8" wide wheel with a 50mm? by the way, the wheel would barely have a lip...
Old Jan 5, 2004 | 09:51 PM
rondog's Avatar
Former Sponsor
howabout a 7.5 width instead of an 8" width on the 19' with a 50mm offset?
Old Jan 5, 2004 | 10:07 PM
NSXNEXT's Avatar
I have 18x8 +50 and I have no problems.
Old Jan 5, 2004 | 10:08 PM
NSXNEXT's Avatar
Here are the specs:
7" rim with +55 offset vs 8" rim with +50 offset
The clearance from stut housing to the inside of the wheel will be 8mm LESS
The outside edge of the wheel will EXTEND an extra 18mm
Old Jan 5, 2004 | 10:11 PM
rondog's Avatar
Former Sponsor
I am ordering wheels from a manufactering company and i wanted to direct them towards our OEM wheel specs but in 18" and 19" diameters. I think the closest to OEM would be 18" x 7.5" 5 x 114.3 with a 50 offset, and a 19" x 7.5 with a 50mm offset, or should i go 7" wide on both diameters, i gotta make a quick decission, gonna order the wheels tonight...
Old Jan 5, 2004 | 10:48 PM
sgmotoring's Avatar
Bleed Honda Blue
I think with a 7.5" width a 48 offset or 8" with a 42 offset is good. Don't forget your rims are wider now. I would want to increase in width evenly, 1/4 inch inward and 1/4 inch outward or 1/2" in and 1/2" out.
Old Jan 6, 2004 | 01:19 AM
CrockPot's Avatar
i hope you're meaning 8" with a 50 offset.
Old Jan 6, 2004 | 02:29 AM
sgmotoring's Avatar
Bleed Honda Blue
sorry for the mistake. I mean 7.5 width with a 42 off set and 8" with a 48 off set is good. I would not want the width to increase evenly. To much negative off set or too wide a rim with same off set, will make the rim stick out of the fender.
Old Jan 6, 2004 | 07:20 AM
fuzzy02CLS's Avatar
I have 17X8 +50 with no problems
Old Jan 6, 2004 | 11:21 AM
mushutofu's Avatar
Don't go 42mm offset if you have a dropped car. Minimum for a dropped car would be +45. I have a 43mm offset but my car is not dropped. The wheels lines right up with the fender.
Old Jan 6, 2004 | 04:24 PM
mantis23's Avatar
Moderator Alumnus
+50 = perfecto... +48 is damn great as well.
Old Jan 6, 2004 | 04:52 PM
oonowindoo's Avatar
Re: need help quick, 48mm or 50mm offset?
thanks
_______________
i am pretty sure it wont rub with 19x8 with 48 offset unless u slam ur car to the ground, then anything will rub. i think alot of ppl here use 19x8 with 42 offset.
i say go with 48 offset because u wanna flush the fender... 50 offset is a little bit too high for 8" rims.
i would go with 50 offset if ur gonnaput on 18x8.5...
Old Jan 7, 2004 | 01:37 AM
sgmotoring's Avatar
Bleed Honda Blue
believe it or not when you lower your car, the rim actually tuck in a little.
neuronbob
23
Jul 16, 2019 10:48 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
