NEED HELP!!! CD ERROR!!!
Hi....just recently I've been getting this CD error PE0 on my 1997 CL 2.2 In the manual it says its a dirty CD but that isn't it. Happened all the sudden. I can sometimes play CD's, but I get the error most times. I read that this is a common error, and sorta a defect with the player. I can hear the player trying to read the CD but it ain't catching. Anyone else ever have this or know a solution??? THanks
I had that same problem in my 99 3.0 cl. It would play for a little while in the morning or something like that and then all of a sudden it would stop and give me that error. It seems like the thing that would spin the cd starts to get stuck and slows down till the cd is not spinning fast enough to be red. The music would play then it would start to get sorta distorted and then ...no music. I had it replaced under warranty at the dealer...they didn't even look at it to see if it could be fixed. Hope this helps.
It happens in my car. I just thought that it was a CD that was too scratched up, but then I put the same CD in a different car and everything works fine. Time to talk to the dealer.....
Well it happened all the sudden....was working great with no problems...then this. Only thing I can think is the heat did it....was like 100 and muggy that day???
I had a '97 3.0-P and mine died within 6 months in the "winter" in FL. Temp was never above 70.
Originally posted by eh7879:
<STRONG>Well it happened all the sudden....was working great with no problems...then this. Only thing I can think is the heat did it....was like 100 and muggy that day???</STRONG>
phillyguerrilla
09-26-2015 11:27 AM
