NE1 using an RPM switch to control their IMRC?
I got everything hooked up for my TypeS IM swap but for some reason the IMRC opens correctly but then it looks like it gets stuck when it tries to close. I have the rpm switch set to open the IMRC at 3500 rpms, which it does. The close setting is set at 8000 rpms, which basically means as soon as the rpms drop below 3500, it is supposed to close.
What happens is the IMRC gets stuck in the open position. If I manually grab the gear on the IMRC and turn it, it will close. I have to give it a little tug because there is some resistance on it. Once I do that though, it spins freely. It feels like it still thinks it's supposed to be open.
I've tried testing it with the IM cable disconnected from the IMRC so it's not an issue with it being too tight or too loose.
It's wired correctly:
Anyone have any ideas? Oh and the rpm switch and IMRC are brand new.
- Yellow to the left contact on the IMRC
- Red wire from the right contact to positive on the battery (yeah I'll find a permanent place for it later)
- Black wire from the rpm switch to ground
- Red wire from the rpm switch to positive on the battery
- White wire on the rpm switch to the rpm test plug near the horn
- Gray wire on rpm switch not used
You have to play with the two nuts that are connected to the cable.
See the silver metal part...there are two nuts sitting behind there and they need to be perfectly set up or the cable will get stuck every time.
Originally Posted by NSXNEXT
that's just it. I disconnected that cable completely and it does the same thing.
The butterfly will stay open just a tad bit when it's "closed".
I'm assuming that's what you are talking about.
Originally Posted by BigLizard
Ok...i'll eat my words.
No, the problem is the IMRC appears to stay open even when the rpms drop below 3500. If I grab the IMRC gear (the part the cable connect to) and try to give a turn, it seems like it's stuck. If I push a little harder, it turns, then it turns freely.
What am I doing: retrofit TypeS IM on a non-TypeS
What does it do: more power for non-typeS owners
I think I might have this issue on my S. Would it throw a code if it stayed open all the time? I remember when I was putting on my CAI the butterfly was open I think. What would happen if it were open all the time would the car run badly?
You need to adjust the cable nuts like BigLizard was saying. At least that is what I did. I dont think taking the cable off will help troubleshoot the issue as the tension from the cable is what helps close it. You may want to troubleshoot the RPM switch as well and just apply a straight 12 volts to both pins. That should open it, when you unhook it should stay open untill you apply some tension to the cable. let me know if that doesnt work and I will mess around with mine a bit and see if I can get it to do the same thing.
Are you using an MSD RPM switch? if so which one? The ones with the interchangeable modules or the one you can program with buttons?
Yeah I'm using the MSD that you program, same as BigLizard. Gonna give it a try.
Thanks for the help.
Neil
Also, I just re-read my post and realized I made a mistake. When I was talking about troubleshooting using straight 12 volts I was referring to the IMRC and not the RPM switch. I'll try to get mine to act up again this weekend so I can let you know which way to adjust. Let me know if you get it working before then.
Trolling Canuckistan
is this the switch http://dagostinoracing.com/index.php...oducts_id=5951
Still not working. Went and bought a new IMRC and tried that and it does the same thing.
The spring on the IM will not close the IMRC. I have to turn the gear on the IMRC pretty hard to get it to close. If I hold the IMRC in my hand I can feel it try to turn when the rpms go under 3500 but it just doesn't close. And again I've tried a brand new IMRC as well as my current one.
It's like it's not processing the close signal.
Just confirming...
I have it set to open at 3500rpms (yes this is right for a TLP) and set to close at 3100rpms.
Correct?
Just confirming...
Correct?
So I called MSD and they think I should be using relay to control the IMRC. Gonna go pick up a cheap one at Autozone tonight.
Question, is the IMRC controling voltage or ground? I believe it's voltage.
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
Take that top plate off , when I was puttining on my im spacers i cleaned out my IM and it was all tar stuff up where the plates open,.. Maybee there stuck too much sh()T up in there!
The reason it's becoming stuck open is because of those two notoroious nuts that are close to the IMRC gears. You have to keep playing with them until it's letting the cable open AND close. If the nuts are too tight they'll keep on the IMRC plates open, but it won't let off the pressure, therefore it won't close the plates.
You don't need a relay. The switch works just fine. The IMRC gets a little bit of voltage so the gears will open.
The spring tension on the IM plate will never close this. I have to grab the IMRC gear with my hand and turn it pretty hard to get it to release.
I realize some have not used a relay but after talking to MSD and they are pretty sure the issue I'm having is a result of the lack of a relay.
I can't cant it to release either using 2 differnt switches.
I think I'm going to try to tighten the butterfly spring if possible
