Navi decoder...
Old May 14, 2002 | 09:45 PM
WebToker's Avatar
Navi decoder...
I posted this before but I am not sure if the right people saw it. The AVC-RGB1, from what I can tell is just a composite to RGB converter. What would be wrong with just feeding the Navi screen a RGB signal?
Old May 14, 2002 | 11:30 PM
WebToker's Avatar
Re: Navi decoder...
bump
Old May 15, 2002 | 07:59 AM
digitalgm's Avatar
"v1 saved my ass ......."
should work -- all you would need is a red, green, blue and composite signal.... should be simple.
AdamR
Old May 15, 2002 | 09:28 AM
AcuraFanatic's Avatar
('''\_(o_0)_/''')
I still don't understand how you could convert a screen like that. Are you changing the projection some how?
Old May 15, 2002 | 09:34 AM
soopa's Avatar
The Creator
wait wait wait wait.
if all you gotta do is feed it a composite rgb signal then why the fuck are we wasting our time with the decoder?
every single piece of video playback equipment i own has RGB output. including PS2.
its gotta be harder then that. doesnt it
someone shed some light on this...
Old May 15, 2002 | 02:04 PM
HellaWhat's Avatar
*Hella* isn't a word.
Correct me if I'm wrong... but I was under the impression the Navi uses RGB while the output of a DVD player is Composite/S-video. I'm under the impression that the DVD Encoder is a bridge between the two?
Old May 15, 2002 | 02:17 PM
bigman's Avatar
'Big Daddy Diggler'
ditto
Old May 15, 2002 | 02:29 PM
soopa's Avatar
The Creator
nope. many dvd players and pretty much anything these days has RGB output.
Old May 15, 2002 | 06:38 PM
Rescuer's Avatar
Evil Bob Knieval
the Nav system does not use S-Video
no you cannot just tap into the RGB wires going to the nav with RGB wires off your playstation or anything else.
you MUST use some sort of decoder. i'm not sure exactly how it changes things, but you cannot mickey-mouse the wires together
sorry, but it would be nice huh?
this has already been tested by quite a few people too, and it just doesn't work that way
Old May 15, 2002 | 11:42 PM
WebToker's Avatar
I guess my question is why?
Old May 16, 2002 | 04:48 PM
peiqinglong's Avatar
Hey Type S Dragon...I was curious to when the next meet is? I wanna check out the NAV conversion you did on your CLS and your car too!
Old May 16, 2002 | 05:25 PM
EricS's Avatar
soopa, which car dvd players/changers have RGB outs? The Alpines only have composite video out.
Old May 16, 2002 | 05:42 PM
Edub-TL's Avatar
Sticky Rice OwnZ joO
is the RGB on DVD players Component RGB and not the same type of RGB that the Navi takes? Seems like that is the reason why the decoder is needed..
I'm betting the RGB is like the RGB computer monitors and not like the type that is used in AV equipment..
Old May 16, 2002 | 05:52 PM
WebToker's Avatar
Is there a difference? RGB is RGB...
Old May 16, 2002 | 05:56 PM
jaysco's Avatar
RGB is not what the DVD players output, they output in component video. Yes the wire are red blue and green, but the output is not the same. Computers output in RGB+H+V, it is the 3 colors plus signals that give the pixels the coordinates on the screen.
Old May 16, 2002 | 07:29 PM
NOVAwhiteTypeS's Avatar
my apex, mp3/dvd player has RCA/RGB.
the reason is probably because RGB color needs some kind of mixing (decoding) done before it can display it right
Old May 16, 2002 | 08:33 PM
WebToker's Avatar
Cool, thanks jaysco, you are right. I totally forgot about H+V.
Old May 16, 2002 | 08:47 PM
Samer007's Avatar
Smack My B*tch Up
Its not just RGB (3 wires)
Its RGB and Sync on our navi.
Most RGB are include a Hsync and Vsync. only.
There is a way to convert Hsync and Vsync to Sync (composite sync) but its actually compliated but possible.
In addition I believe not all RGB are 0.7p-p (?).TTL Some are not.
here is Hsync+Vsync to Composite sync if it helps anyone:
Old May 16, 2002 | 08:59 PM
Samer007's Avatar
Smack My B*tch Up
all you need is this:
http://www.semiconductors.philips.co...h#blockdiagram
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
us285126
Oct 2, 2015 02:03 PM
jmaxima03
Sep 27, 2015 10:22 AM
Cgannotti
Sep 25, 2015 05:04 PM
