Name that part..
Old Mar 12, 2008 | 07:30 PM
memnoc's Avatar
8th Gear
Name that part..
Hi all,
This is my first post, but I've been lurking for a while. Seems like most of the other questions I have had were already answered about a dozen times so I never needed to post before now.
A while back I hit the pothole to end all potholes (it was filled with water so I didn't know it was there). Anyway, it broke my wheel and I had to get that replaced. Lately, I've been noticing a clunking noise from that wheel (right front) when I go over speed bumps. I took it in and they said it was a broken endlink. I ended up putting some Moog endlinks in, but the noise didn't go away. Today I decided to look around for any obviously broken parts, but couldn't see anything in the suspension. I take a look in the engine bay and sitting on that plastic piece on the bottom I found these guys. Anybody know what they are? Piece of a motor mount?
Old Mar 12, 2008 | 07:38 PM
rjurado_1215's Avatar
looks like a control arm bushing
Old Mar 12, 2008 | 07:49 PM
PowerRev's Avatar
That goes on top of shock
Old Mar 12, 2008 | 08:20 PM
fuzzy02CLS's Avatar
From the service manual that looks like...
Self locking nut
washer
rubber bushing
that does indeed go on top of your front strut. If you look at the top of your struts from the engine bay I'm sure you'll notice if it's missing.
Old Mar 12, 2008 | 08:26 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
wow, yeah remind me of the top of the strut, your pictures made it seem really huge.. i suggest you look asap..
https://acurazine.com/forums/showthread.php?t=168436
Old Mar 12, 2008 | 08:27 PM
memnoc's Avatar
8th Gear
Thanks, I'll go check it out. Assuming I can't do anything with it right now, what should my course of action be? I set up an appointment for monday at the dealership because they won't have a loaner until then. Should I call and stress that I need to come in pronto or is this something I'm better off fixing myself?
Old Mar 12, 2008 | 08:29 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
it's not that hard to fix, just put the rubber, the washer part, and then tighten the bolt, unless i remember wrong..
definitely unsafe to drive it though
Old Mar 12, 2008 | 08:40 PM
memnoc's Avatar
8th Gear
I don't mean to second guess you guys, but if I was looking at the part I think you were referring to, there's nothing missing. Here are a couple more pictures to help out.
Both sides looks like this. There doesn't appear to be anything missing, correct?
Here are the parts again with a ruler for reference.
If it helps, I found the parts toward the front of that car. I was able to get to them by unhooking part of the bumper on the bottom and just reaching in there.
Old Mar 12, 2008 | 08:52 PM
Nutshell's Avatar
thats a strut rod bushing, washer and bolt. they are known for working themselves loose on hondas. i had a thread on here somewhere about changing them. they will throw your caster of big time seeing as they keep the wheel from moving forward or backward under braking/acceleration.
Old Mar 12, 2008 | 09:06 PM
memnoc's Avatar
8th Gear
Ok, I guess I'm a little confused. In the picture above of the strut, isn't that the bolt, bushing and washer safely in place? Or is that something else? Also, this 'bolt' doesn't have threads on it and is hollow. Does it fit around some bolt that's probably floating around in my engine bay?
PS: rp_guy, I'm going to be heading to Edmonton in a few weeks for work. A friend of mine (with a much nicer CLS) is also going.
Old Mar 12, 2008 | 09:24 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
https://acurazine.com/forums/showthread.php?t=193382 ??
and edmonton alberta right? what u doing here ?
Old Mar 12, 2008 | 09:31 PM
rp_guy's Avatar
'03 ABP YA4-S 6MT
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Silvaccordex01's Avatar
Yeah thats either your strut bushing, or your radious rod bushing (Strut Rod) The radious rod is the long rod that attaches to your lower control arm and goes forward and connects to your front subframe. If that bushing is missing that would definatly cause a clunking noise
Old Mar 12, 2008 | 10:06 PM
memnoc's Avatar
8th Gear
rp_guy:
I work for a company called National Oilwell Varco. I'll be doing engineering over there for about 3 months. And yes, Alberta.
Old Mar 12, 2008 | 10:12 PM
memnoc's Avatar
8th Gear
OK, it's too dark to go check it out and I don't have a flash light for some reason. Considering I drive 37miles to work and back every day, is it unsafe to wait until Monday to take it in? Now that I have pieces of my car sitting on my desk while my car is in the driveway, I'm a little worried.
Old Mar 12, 2008 | 10:14 PM
aznboi2424's Avatar
Originally Posted by memnoc
rp_guy:
yea, the engineering ruler was a give away.
<- studying engineering
Old Mar 13, 2008 | 08:49 AM
fuzzy02CLS's Avatar
They may be parts that just fell into the engine bay & no one ever retrieved them. They may be old un-needed parts. You need to get your car checked out & see if anything is missing or loose.
Until your sure I wouldn't be driving it that far.
Old Mar 13, 2008 | 08:57 AM
spdy0001's Avatar
I now drive an accord....
Exactly what I was thinking from the beginning of the post.
Its still strange though that you car is making noises. Perhaps someone who recently worked on the car forgot those parts?
Old Mar 13, 2008 | 05:59 PM
memnoc's Avatar
8th Gear
Well, I decided not to risk it and brought it to the dealership. They verified that it was the radius rod bushing and replaced it and tightened everything up. No more noises, so that's good. They claimed they looked over everything, but I'm sure this isn't the last problem I'll have because of that pothole. Anyway, fixed for now. Thank you to everybody for helping - this turned out to be a productive first post.
Old Aug 5, 2008 | 04:22 AM
aznboi2424's Avatar
now who wants to help me? OK guys, i need some help identifying this part. Mods please feel free to chime in. It the part thats covered in white lithium grease. Its how I found out what made the creaking sound.
Old Aug 5, 2008 | 10:44 AM
ljmushock's Avatar
good god, who sprayed all that grease on there? That if im not mistaken looks like the stabilizer or sway bar bushing?
Old Aug 6, 2008 | 03:27 AM
aznboi2424's Avatar
that was me. It didnt have that much before but the noise came back in 2 days so i sprayed more and then i found out it was that part making noise.
23109VC
Oct 9, 2017 04:25 PM
alec3369
Dec 29, 2014 01:12 PM
Whatshisface
Mar 6, 2014 11:09 AM
cellowiz
Jun 7, 2008 08:32 AM
